Page 2 of 2 FirstFirst 1 2
Results 16 to 24 of 24
Thread: What size front tire on your 200x?
    Aug 2007
    Moab, UT
    1,807
    ctbale is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    anchorage alaska
    289
    great info! your "moderate braking" was the first thing that went thru my mind when I first saw the tread pattern of the Kenda Max, would have been better if one outer row of knobs were twisted 15 or 25 degrees.
    Crawford, CO
    28
    Thanks for all your advise!! I think I'm going with the Kendra front max but what I've been reading is that some of these front tires only have a 1 ply rating some with 2 ply rating, 1 with a 4 ply rating Why? Don't you want something like a 4-8 ply rating? It would suck to be doing 45 MPH, hit a rock and crash, burn and die because of a 1 ply rated front tire. The Kendra front max tires on eBay don't list how many ply they are. Might as well just have a inner tube for a front tire. Before I buy a tire I'm going to make sure it has as many ply's as I can get!
    Anyways, I would like your feed back on this subject and for you to check out your front tires and see what the ply rating is. Thanks, Chris
    As I walk through the valley of the shawdow of death I have no fear because I am the meinest MF in the whole valley.
    -Gen. George S. Patton
    http://www.youtube.com/user/strangefire1?feature=mhum
    Aug 2007
    Moab, UT
    1,807
    Why don't you click on the links in that thread I posted? The ply rating is listed for each tire. As far as your reasoning on ply ratings, more isn't always better. The more ply a tire has the heavier it is and the rougher riding it is. More ply means greater puncture resistance and less flex. Usually it's best to run the least amount of ply you can get away with for your terrain. It all comes down to handling.
    Mankato Minnesota
    147
    What size rim is supposed to be on the back off the 84 200 X?
    Sep 2007
    100mi west of Chicago
    3,582
    8x8 on the rear of the 1st gen 200x. Check this out
    http://www.3wheeler.org/vb/showthrea...-bolt-patterns
    Rob
    Mankato Minnesota
    147
    Anyone have a spare set of rear rims for an 84 200 X?
    Mar 2011
    Ohio
    236
    I have a spare set but shipping would probably kill you.
    Aug 2007
    Moab, UT
    1,807
    Quote Originally Posted by Jaketrimoto View Post
    C'mon man! Thread hijacking. Post questions that are unrelated to a thread in your own thread or in the proper section.
