anyone try one of these yet? http://cgi.ebay.com/ebaymotors/1985-...QQcmdZViewItem
I emailed them and was told its 10:1(with chamber opened up to the bore, no squish band), o-ringed cylinder, and +2mm intake reliefs, which they also say they have(33mm intakes). Piston appears to be just like the 92mm JE, only bigger and less dome, and ~25 gms heavier. their sleeve is 4.055 o.d., leaving .120 wall @ 96mm. I've been using the xr500 sleeve which is also .120 wall @ 92mm, and .080 @ 94mm. I 'd be concerned with heat and strength any less than that, especially with the rock that the larger pistons have.
