Results 1 to 3 of 3
Thread: Whats an easy way to bend sub-frame straight again?
    Snohomish, Wa
    1,028
    Hi, my sub-frame on my 85 250r is bent. I what is the easiest way to bend it back would be. I would like to try to salvage the powder-coating but I understand that I may not be able to do that. Any info would be great.
    Thanks
    Tyler
    85 ATC 250r -Under Construction
    86 TRX250r
    05 KFX400
    02 400EX
    Dec 2010
    washington state
    681
    heat then or leverage may work but round tubing will callaps , the other way is cut it out then weld in a new piece, good luck
    GOT MUD?:
    Dec 2006
    el centro
    252
    leave the sub frame bolted to frame ... remove platics and are box if needed... use a 3 to 4 ft cheater bar... I use the one out of my floor jack.... slide it above one side and under the other .... now use force lightly.... eye ball it until it looks good..... I do it all the time to my MX aluminum sub frames.... I've never needed to buy a new one ... I've never used heat....Brett
    speed kills
