Results 1 to 9 of 9
Thread: 86 Tecate
    norcal
    72
    86 Tecate
    I couldn't really afford to buy it but I did because I rarely see them for sale in Norcal. I think it has a widened axle, the rear shock is toast, and it has low compression. I could push the kickstarter down by hand. Besides that it looks pretty good. The only bad thing is maybe it has a kx dirtbike motor and not the original. The barrel is aluminum color not black. The case had kx250...... is it supposed to have kxt250.... for serial numbers?
    Attached Thumbnails Attached Thumbnails droid 2010 1150.jpg   droid 2010 1152.jpg   droid 2010 1157.jpg   droid 2010 1156.jpg   droid 2010 1159.jpg
    OK
    5,450
    I'm pretty sure all of the Tecate's had KX and not KXT on the motor serial number (All of my 84-85's do). The Barrel may have been stripped or painted a different color when the PO did a top end rebuild.
    Rides:
    1982 ATC70 (Lifan manual 125)
    1987 LT80 (piped, widened)
    My feedback thread
    RIP Trace.. Godspeed.
    Crest California
    3,014
    Bigger pics!!!
    Also, do the KX engines just drop right in? Seems like a lot of stuff is interchangeable, so why wouldn't the engines be?
    LED obsessed
    2015 Yamaha FJ-09
    OK
    5,450
    Quote Originally Posted by Xpress View Post
    Bigger pics!!!
    They will for the appropriate year KX250 for KXT250 frame, but the KXT transmissions had stronger gears made to contend with the shock load of 2 rear tires and an axle to spin them on. People have run the KX trans in the Tecate before.
    Rides:
    My feedback thread
    Crest California
    3,014
    ^It's always something like that isn't it? I bet you'd be fine if you weren't nuts on the gas and such. But wait, then why do you have a Tecate?
    LED obsessed
    2015 Yamaha FJ-09
    norcal
    72
    Bigger pics!!!
    I am taking pictures with a droid I don't know how to make them bigger, maybe I'm doing something wrong.
    Crest California
    3,014
    Okay, you have your camera in multi-media messaging mode, which means that it will take smaller pictures so that they are easier to send through your text messages.
    Go into the camera, and then go into the settings, I believe it looks like a gear. Then scroll down to picture size. Set it to LARGEST. Droid phones normally have decent cameras in them so they can take rather large photos.
    LED obsessed
    2015 Yamaha FJ-09
    norcal
    72
    That is good to know I was thinking it had a kx engine. I tried looking at some pictures of stock motors and they were all black so I thought the bare aluminum cylinder was possibly from a mx bike. Thanks for the info.
    norcal
    72
    I'll give that a try thanks.
