Results 1 to 10 of 10
Thread: 350x timing marks wrong?
    texas
    567
    Last night i was out doin a valve adjust to try and fix a ticing (pita). Idles rough now so i gotta take off the rocker box to get a good feel. But, i noticed the T doesnt line up when its supposed. When lined up the rockers would be tight. So i turned until i saw both rockers go loose then did my adjustment. Is it possible thats the flywheel or cam is in wrong? It runs strong even with the crap adjustment i did.
    Also, anyone know the manual page for replacing the timing chain? Cant find it
    Jan 2008
    nc
    734
    When you get it lined up with the "T" and the rockers aren't loose, go another 360 to the "T" and it should work. Just did this on mine
    texas
    567
    mine still didnt. they got lose about 90 after. i ended up just watching the valves til they wete loose and doing it. need to readjust cause i cant get a feel for it in that tight spot. any tips in that guys? the exhaust valves were easier. btw im doing this in the bike
    ailll1's Avatar
    ailll1 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Dec 2009
    Québec
    405
    Timing way off?
    1985 ATC250sx
    1984 ATC200s
    1984 ATC200x
    HONDAS FOR LIFE!!!
    They could be too tight. I routinely back them way off and then find "T", then go another rotation if I can see rockers moving. Make certain you aren't mistaking "F" for "T". The only way "T" is off is if the cam chain isn't on/inline with the cam timing or the flywheel key is sheared (rare on a 350X). If this was a running motor, that valve timing should be fine and more than likely you were too tight or on "F".
    texas
    567
    Its hard to verify the letter but i guess they were too tight. It ripped. I guess ill line up the t again and loosen them. Is the t going to be on the top or bottom. I see 2 lines and somewhere else there is 2 letters i thought one was i. Anyways, looks like i blew a shock seal in my 500 mile commute today. I had oil sprayed out on my wheel from the fork. Am i out of commision on riding it now? It still feels fine...
    Jan 2008
    nc
    734
    It ripped???
    after you see the 2 lines, next will come the F and then the T.
    texas
    567
    i didnt get to look at it real close in the back of my truck. the boot looked good so im not sure where it came from. that was just the closest thing i could come up with.
    I think it had a trikeasm, glad it missed your eye
    Yes, it fires "F" before "T"...... you want the second line. It does suk that the flywheels are tough to read unless you pull the cover and dremel the line in place. Thats why I normally use a straw in the spark plug hole to confirm TDC..............
    texas
    567
    Sounds like a plan dc. Well im going to be replacing the timing chain and i cant find it in the manual. Can i do it while its in the frame? Ill be at a friends and wont be able to take a break. Remove the clutch and oil pump. From there how do i make sure its timed once in place? I wont be removing the sprocket so just TDC and lobes down? Im tryin to keep it alive dc i know you hate holding hands and i seriously cant find it in the manual
    Nvm im an asshat. The manual on the ipad doesnt make it obvious it skips with shortcuts
