Results 1 to 8 of 8
Thread: --Are '84 Tecate Rear rims same bolt as '86 ???
    Plattsburgh, NY
    2,311
    picked up an '84 tecate. has really nice rear rims. i believe they r stock. they r in good shape. i was wondering if they r same bolt as the '86 rear rims, or if the hub splines r the same is the bolt pattern isnt. help me out here please.
    what is interchangeable from the early model tecates to the later ones??
    TPC TRIKES
    FSU Powersports
    RNS Powdercoating
    OK
    5,450
    The 84 pattern is 4/4 (8" or 10") or 4/101mm the 85-87 are 4/156mm.. (10" only) the splines are interchangeable between 84 and 85. An 85 KLF185 has the same axle splines and will give you 4/110 pattern..
    oem 84 wheels are gold painted steel. The '85 uses the same wheels front and rear and shares the rear wheels with the 86-87. 85-87 are aluminum wheels.
    Rides:
    1982 ATC70 (Lifan manual 125)
    1987 LT80 (piped, widened)
    My feedback thread
    RIP Trace.. Godspeed.
    Plattsburgh, NY
    2,311
    ohhhh good to know. so maybe this is an '84 with '85 rear hubs and rims. the rear rims look like that of an '86. they r aluminum. or maybe its an '85. how would i figure that out??
    so i could use these rear hubs on an '86. thats cool
    by the way i found the tecate parts interchangeability threads. good stuff in there.
    TPC TRIKES
    FSU Powersports
    RNS Powdercoating
    Sep 2005
    MICHIGAN
    2,027
    I disagree about the axle splines. 84-85 have 13 course splines. 86-87 have 24 splines. So no, a hub from 1985 is not going an 1986 axle. A 4/156mm rim will but not a hub.
    86 T3
    84 T3
    86 KX250
    OK
    5,450
    Quote Originally Posted by nd4speed View Post
    He is 100% correct about that.. I knew that. Brain fart on my part for sure..
    Rides:
    My feedback thread
    Plattsburgh, NY
    2,311
    Ok thanks guys. I'm sure I'll have more questions. I think the tecate I just picked up is an '85. It's got disc brakes on the front and the 4/156 hubs and rims.
    TPC TRIKES
    FSU Powersports
    RNS Powdercoating
    I thought you already knew it was. You told me you thought it was an 85 and I confirmed it.
    Plattsburgh, NY
    2,311
    yeah i thought it was from the disc brakes. and rear rims but from what i have been reading about swapping parts, i guess they could have been switched to that. but more likely it is an '85. i was just stating it in this thread because in my first post i said it was an '84. so that way anyone giving advice or info would now know it was an '85. but yes u already knew cuz i talked to u about it earlier but not on this thread.
    TPC TRIKES
    FSU Powersports
    RNS Powdercoating
