Results 1 to 15 of 17
Thread: WOW! a wealth of parts! check this out!
    May 2011
    Foothills of the Adirondacks
    104
    Selling a decade collection of Honda ATC aftermarket + nice OEM parts - $50 (canastota ny 13032)
    After over a decade of collecting hoarding and building vintage 3 wheelers, im changing my hobby dirrection towards off road lifted trucks.. So its time to part with most my collection of cool rare parts from over the last ten years of being a parts whore hoarder.. Ive got from nice clean OEM to NOS OEM to NOS aftermarket to used hard to find aftermarket to run of the mill everyday average find trike parts..
    first is my old skool ATC90 race bike build project.. I have aquired every part to build an entire ATC90 with 90% vintage new and used aftermarket parts. when built it will be a completely aftermarket ATC90 replica from the late 70s.. Here is a list bandito tube frame, chrome HD forks with dual axle positions, PCCC suspended front end tripple clamps and forks, HD stock length axle i think is a NASA, 2.5 inch billet H&S 3 bolt hub spacers, a super rare galvinized Webco Inc motor skid plate, CMP brush gaurg / nerf bars, 3 sets of PCCC Turbo two piece aluminam wheel halfs (12 wheels halfs four are 3 on 100 and eight are 4 on 130 bolt pattern), 2 NOS malcolm Smith polished alum rim halfs 3 on 100, basanni super trap and hooker header exhausts, NOS BARP Big Als streaker cams, intakes, vented dip stick crank case vents, NOS finned tappet covers, chrome six pac racs, ciebe baja desert light, NOS vented front fenders, vented Maire number plates with bolt on numbers, over sized carbs with matchen intakes like POSA BARP and unknowns, NOS PCCC chain tensioner, NOS oil cooler kit, NOS BARP 7/8 steel slip on pegs, allen head bolt kits tail lite lens and intakes, 16 in burris flat track tires, polished dick cepek rims anodized gold mithells..ect..ect..ect
    reproduction Hondaline stripe kit sticker sheets, 22 stickers per sheet less than only ten sheets left.. $75 shipped
    1987 J arm banshee parts
    roll design +2+2 arms for the j arm frame--sold
    LSR.. Lone Star Racen +2 chrome swinger with acentric dual row bearing carrier
    red and yellow race cut front and rear fenders
    seat
    working front brakes,
    steel dg nerfs
    FMFs--sold
    rear axle
    steering steem
    1987 honda 250X motor and complete frontend parts
    NOS new old stock Maire fenders all old school dull finish, plus other NOS aftermarket 3wheeler bolt ons..
    85-86 TRI-Z yellow
    2 rear low pro
    3 vented front
    1 set rad shrouds--sold
    1 set fork gaurds--sold
    1 vented mesh number plate--sold
    84-85 tecate fat tire t3
    2 fronts 1 red 1 green--sold
    1 set of green fork gaurds for drum and small disk--sold
    86-87 tecate
    green fork gaurds--sold
    81-82 250R
    Red vented maire num plate--sold
    Big Als chrome six pack rack bolt on grab bar new in box
    Sand Scorcher Big Chrome head light gaurd
    NOS WHITE MAIERS
    1 low pro rears--sold
    1 reg rears
    83-84 250R white
    3 low pro rears
    4 vented fronts
    3 reg fronts
    2 set of super scoops--sold
    3 plastic short track tanks
    83-84 250R red
    2 sets super scoops--sold
    2 plastic short track tanks
    4 NOS head light gaurd and mounts
    atc90 older 110
    1 red 1 white vented front fender
    85-86 250R
    3 sets red rad shrouds
    1 red 4 gal tank--sold
    1 white 4 gal tank--sold
    Honda atc185 200e m s fat tire trikes
    6 white front fenders
    Custom vinyle gas tank covers for first gen 200x 200s 250sx and 85-86 250R, any color and carbon fiber
    12 NOS aftermarket light gaurds not hondaline both generations of aircooled 250r, both gen 200x, 250SX
    used clean OEM and used aftermarket trike parts
    1985 86 87 ATC250SX
    red oem light and new gaurd--sold
    front rear racks--sold
    ignition switch dash key and helmet lock
    TRI-Z
    aluminam top mount fuel tank--sold
    DG pipe--sold
    yellow mess vented num plate--sold
    yellow head light--sold
    85-86 ATC250R
    billet intakes with rubber adapter boots for bigger carbs 1 H&S with boost bottle port and 1 POSA
    Selvys exhaust head pipe and silencer
    Selvys Sonic ported 250cc cylinder needs resleeved
    CRF sectional head pipe
    Answer ignition roost boost
    Hi Flite desert seat, pan foam and new carbon fiber seat cover.
    Hondaline over fender NOS
    near mint 85 and a 86 style head lights complete and working,
    used white rear low pro fenders
    38 mil Kiehn flat slide--sold
    40 mill Kiehn round slide.
    white maire mesh vented num plate with mounts and black nums
    NOS red maire over fender
    West Coast extended Hubs--sold
    ESR pipe--sold
    first gen 200X 83-85
    2 clutch side cases with oil cooler mod done drilled and tapped with brass elbows to oil lines
    real nice clean OEM jugs 2, rocker boxxes 2, heads 3, and cams 2 with no wear
    lockhart oill cooler, lines, and case with mod--sold
    phasefive head pipe and alum silencer--sold
    28 mil intake and matching 28 mil keihen round slide--sold
    85 blue shock WP revalve--sold
    air cooled 250R 81-84
    RPM TURBOED FULL LOBE CRANK. full circle lobes that have been turbo cut
    RPM ported and decked cylinder
    2 DG star burst radial gold anodized heads
    2 mild unknown clean ported jugs
    shaved and stock heads
    billet intakes for bigger carbs and boost bootles
    83-84 full Bassani pipe--sold
    81 DG head pipe--sold
    85-86 ATC350X
    NOS PK Pipe--sold
    3 NOS NASA fork braces--sold
    hondaling headlight gaurd
    nice oem headlight--sold
    +1 Dura Blue swinger--sold
    DG pipe--sold
    ASTRO 4 wheel conversion kit frame
    real nice 1985 ATC250R clean 90% original.. $2000
    1984 ATC70 all original but exact repro black seat cover and a honda chrome headlight kit. real nice, real clean. runs great. one dry cracked rear tire needs replaced.... $800 obo
    1985 ATC70 pit bike.. 110cc auto motor custom kick start to pull start handle conversion, super trapp pipe, custom pit bike pegs and foot brake pedal.. custom grab bar with cooler rack,, bar raisers and baja lights, billet rear view mirrior, carbon fiber seat cover, 2in billet wheel spacers 3 gold anodized rims 16in flat track tires.. nice oem honda fenders and tank., complete custom big kids pit bike,,. wont stay running.. $800 obo
    Old school drag trike.. Aftermarket tubular Nicolson 90 frame, with heavy duty chrome rigid forks.. Mild ported air cooled 250R motor, DG head, Boosen rad valve billet intake 36mil kiehen D slide carb K&N pod, FTZ outta frame drag pipe, 6 foot wheeie bar, 2 piece alum PCCC Turbo wheels with new 4 sows and a new knobbie up front.. custom black and red diamond tuc and roll seat.. one off head turner looks of trick custom parts..... $1500
    I got a lot email me and well talk..
    http://syracuse.craigslist.org/rvs/2441477352.html
    pics at the link! I don't need any of it but figured I should share the ad!
    Quad? whats that?
    OK
    5,450
    It's been posted before. It's Freaksfix off of the site.
    Rides:
    1982 ATC70 (Lifan manual 125)
    1987 LT80 (piped, widened)
    My feedback thread
    RIP Trace.. Godspeed.
    May 2011
    104
    sorry, my bad!
    Quad? whats that?
    Dec 2010
    845
    i would kill for some of thoses parts....jk
    MY TRIKES! :
    1- 85 250r NOS engine
    1- 1985 350x
    1- 82 250r + Parts
    1- 86 250es Big Red
    1- 85 200x
    2- 84 200es Big Red
    1- 84 200M !!MINTY!!
    1- 73 Atc 70 (project)
    MY Snowmobile's!!
    1999 Polaris Indy 440
    1999 Ski-Doo 583
    1993 Polaris Indy 500
    My Dirt Bike
    1986 Dr100
    OK
    5,450
    Quote Originally Posted by Tuff View Post
    sorry, my bad!
    No worries, it was a month ago..
    http://www.3wheelerworld.com/showthr...rts-and-trikes
    Rides:
    My feedback thread
    Dec 2010
    845
    i remember seeing this thread before to but who cares if somebody posts it again
    MY TRIKES! :
    1- 1985 350x
    1- 82 250r + Parts
    1- 86 250es Big Red
    1- 85 200x
    2- 84 200es Big Red
    MY Snowmobile's!!
    1999 Ski-Doo 583
    My Dirt Bike
    1986 Dr100
    OK
    5,450
    Quote Originally Posted by gomer202 View Post
    The point I was trying to make was in the hope that we wouldn't have a lot of duplicate posts in this section. I can look to see if things have been posted before so can you.. hopefully.. It doesn't seem like much to ask.
    Rides:
    My feedback thread
    May 2011
    eden,ny
    3,481
    in a lil less than three years you have posted almost 4300 times I'm betting you posted the same thing more than once. just saying
    OK
    5,450
    Quote Originally Posted by ben6626 View Post
    I'll bet you're wrong.. If you got the time you go ahead and prove me wrong...
    It amazes me that instead of maybe taking away a little information, they'd rather talk sh!t... If you have to post "just saying", maybe you shouldn't post it..
    Rides:
    My feedback thread
    Aug 2007
    Moab, UT
    1,807
    "Just sayin" is a favorite standby term used by newbs. What he meant to say was, "I haven't earned my stripes but I like to pretend I have."
    May 2011
    eden,ny
    3,481
    I wasn't talkin shlt! I know from experience that even searching for something on here you can't always find it even with exact or close to wording. I will however call you out on counterdicting yourself though. "no worrys it was over a month ago" then biltch about posting info that has already been posted? not trying to get anything goin but read what you already wrote before saying something different
    OK
    5,450
    My point had been made.. You are starting sh!t. Why else would you post. As far as my post count I have about a 1000 other posts in the Tecate Group I started that you joined. It amazes me how much you newbies think you run things here. Why would it be a good idea to have a bunch of the same posts about the same craigslist post? Did you even think of that fact before you started typing? Of course not, it never even occured to you. If you would try to search for what you are posting you might find it. Everyone just keeps getting lazier and lazier.. It's too hard to do a search.. waaahh.. You know from experience... Apparently you don't.. You know more than everyone in 3 months huh??
    This is not your site or mine.. The least we can do is to help police the site ourselves to a point by not taking up space with duplicate threads about the same thing. If you don't understand that concept.. maybe you will in about 2 years and 7 months..
    Rides:
    My feedback thread
    May 2011
    104
    sorry to cause such a storm. would a moderator please delete this thread?
    dcreel: this newb does not think he runs or owns this site, and has a lot of respect for the membership here, but I do have lots of good info and experience that I bring to the table. not just wheelers but also sleds, and as a GM Master Tech w/25 years experience, I would be happy to help my fellow members with any issues with their vehicles, as well.
    yes, I posted the link without a search because its from NY and I figured there are not too many NY'ers here so I expected it hadn't been posted already.
    I guess with this sites attitude toward newbs, maybe the bold is a waste of my time and I will go back to just reading here as a guest(been reading here for years)and contribute nothing.
    again, I apologize for creating any drama. It was never intended. enjoy.
    Quad? whats that?
    May 2011
    eden,ny
    3,481
    I'm here to learn and share what I know isnt that what its all about? 3months,3 years I doubt if either of us know all there is to know. and I love the tecate group lots of good info there. My origanal point was its not that hard to make a duplicate thread even after searching. I wasnt trying to take a personal hit at you dcreel so please dont take it that way
    OK
    5,450
    Tuff, I apologize for coming off the way I did. I made a remark to your post, and I figured that was that. I figured the message would have been received. The diatribe afterwards was not pointed at you and I apologize. If everyone would have taken the point I was trying to make and moved on it never would have happened. It just seems like respect is a forgotten art anymore. Especially on an internet forum.
