Results 1 to 15 of 65
Thread: my 200x Lifted MONSTER in the works
    nicker71's Avatar
    nicker71 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jun 2003
    Wright City, Missouri
    385
    I got my 350x shock back from dirtworks today so I decided to throw together the parts I had to see what I have. Shock works nice I had it shorten about a inch. Of course its a bit soft, because the 350x shock has a softer spring than a 200x and the longer swingarm. I dont have any turns yet on the preload adjuster but if that isnt enough we plan on finding a heavier spring. Im using the stock 200 linkage.
    In these pictures I have 350x trees but using 84 250r forks. Im planning on using my 350x forks because they are about .5 inch longer. I dont have a 350x wheel yet, so these will work until i find a wheel. I also have a 25in tall matching swamplite tire on a black rim, but its at my friends house, so Im threw on my 250r tire. This tire is a 24in. I added some blocks and then a piece of wood to figure out how much more lift I want to add to the front. 3.5-4.5 in more should do the trick. I figure a rough increase of a inch just by adding my 25 inch tall tire and the 350x forks.
    Anyone have any ideas on how to make the front taller?? I think I may look into have a extension that can be bolted to my forks up top. Something like bolting the extension to the upper fork tube and having it clamp to it and then slide it up in the upper tree like it was the fork.
    Future plans once I get the height where it needs to be include fresh powdercoat new plastic with tank. I have a 185s motor thats prob going in it, but I may throw my 200x top end on it.
    The lower number is with nothing under the front tire. The other is with a four inch block
    Your steering rake is nearly verticle, that rear shock mount is gonna have to be moved or the steering neck adjusted to compensate or it won't handle very well....
    nicker71's Avatar
    Jun 2003
    385
    Im not really to concerned about handling on something that going to be nearly 20 in high off the ground. But if I I have a something machined that could lengthen the fork tubes then I coulld have it made to fit my already lengthen 200x forks which would put he rake back in.
    I could always go back a couple sizes on the rear tire length.
    Dec 2010
    845
    That things a monster
    MY TRIKES! :
    1- 85 250r NOS engine
    1- 1985 350x
    1- 82 250r + Parts
    1- 86 250es Big Red
    1- 85 200x
    2- 84 200es Big Red
    1- 84 200M !!MINTY!!
    1- 73 Atc 70 (project)
    MY Snowmobile's!!
    1999 Polaris Indy 440
    1999 Ski-Doo 583
    1993 Polaris Indy 500
    My Dirt Bike
    1986 Dr100
    chuckiedog04's Avatar
    chuckiedog04 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Mar 2011
    minnesota
    369
    what type of riding do you plan with that beast? mudding, just driving it, or like more jumping?
    ontario
    1,131
    thats sweet
    1984 110 project
    1984 125 parts bike
    1983 honda 200x
    19 85x2honda 200x
    1985 honda 250sx
    1985 honda 250es
    Mar 2011
    swfl
    16
    my buddy had a bike like that. it wasn't much good for anything but wheelies. he had a wheelie bar with a wheel on it to keep it going..lol
    BiGDawG's Avatar
    BiGDawG is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Millington, Michigan, United States
    384
    makes me wish i didn't ride my daily.. i'd like to lift mine a bit
    nicker71's Avatar
    Jun 2003
    385
    My brother and I would always play around in the creeks years ago. We would always try to out do one another by crossing the deepest water crossing. Thats where the idea came from, but this will be more of a show piece just to drive around my sub division and stuff. Im sure it wouldnt be good to jump. I have a regular 200x still to play with and i just got a 84 250r too. And of course my yfz450 xc race quad.
    Once I figure out how to raise the front 4 more inches I take some more pics.
    Ripley Tn
    1,363
    your best bet would find some dirtbike forks that are longer and machine the tripple tree's neat wheeler
    85 Atc 70
    86 Atc 125m
    85 atc 350x
    86 atc 250r
    86 Atc 250r TT build
    85 Big Red bought brand NEW
    2012 Honda Goldwing Gl1800
    Oct 2006
    Wapakoneta
    815
    find a set of xr200 forks from the early 80s. They bolt onto the 200x triple trees and are longer than the 200x forks by a few inches. That should help out your off set and balance out your stance of the trike without sacrificing lift.
    nicker71's Avatar
    Jun 2003
    385
    I did this to my other 200x using the xr forks. The 350x fork are still a tad longer. But it gave my other 200x a better stance.
    O.C., Oregon
    921
    Thats things pretty damn cool i must say!
    1978 ATC70 w/ Piranha 140cc
    2017 YZ 250x- Braap
    This thing's a hit with the newbs. Says a lot.
    ametzker's Avatar
    ametzker is offline At The Back Of The Pack Arm chair racerFirst time rider
    Oregon
    170
    Sweet man. Looking at those initial pics brought me back a few months ago on my build. That should be fun. It looks like the swing arm is extended. How much farther back is it taking into account angle?
