how would i go about removing the rear end bearing and seals???
1984 Honda 200s CATERPILLAR, Rear Tracks (coming soon) and rack
oh heck yeah, the motor is going black, i just havent gotten to town to get the proper paint yet
sorry guys, i went on a suprise trip with my parents, but im back!
motor should be painted today..but i still havent sotten the parts i need to put it back together yet
so..today i went over to our small engine repair shop and he had a flywheel puller, and let me use it for free!
so i figured out my no spark problem..there was bits of the exciter coil stuck to the flywheel..yay..so i ordered a new one, when it gets here i will put the motor in.
ok, now that break time is over.. lets finish this thing!!!
i bet you guys thought i forgot about you?? well..truth is i lost interest with this mid summer and now im back on it because my freind wants it done, haha.
i have the forks attatched to the frame and i just installed the rear bearings and seals, and the tank is at my buddies body shop getting the dents pulled.
i still need to get,
coil assembly
recoil
and possibly a rear axle, because i think i f'ed up the threads on one side.
RIP Ninja!
Trike Fest 2011, 2012 Vet!
Trikes Currently Owned:
87 Big Red 250es
83 Honda 200s
81 Honda Atc 70
(4) Suzuki ALT 50's
Yamaha YT 60
did you see where i live??? if your shure..that would be absolutly awsome!!!
and its the coil assembly under the flywheel.
Dude, looks good, can't wait to see the finished and runnin, good work!
i gotta question, would flat black engine paint look ok?? i cant find high heat gloss black to save my life!!
I think flat is 100 times better than gloss. I personally have never been a fan of gloss black in any application.
Also, I can't wait to see the CAT project completed. Such a unique idea.
does anyone have any tips for painting the engine or is it as easy as it seems??
It's pretty easy, just clean it real well and tape off all the holes and bolts and lines and whatnot that you don't want painted. I use a scotch brite pad to rough it up and then clean it again with paint prep cleaner/degreaser, or if you can't or don't want to get it some acetone or carb cleaner will work. Then paint. Drink beer and watch dry. Enjoy![]()
Foolin'
Well, when I have shipped to Canada in the past the "Buyer" which is you would pay all of the fees once it gets to the courier service in Canada. Let me do a little more research on that. What is your postal code.
If the part you need is behind the flywheel you need the stator or the primary. I do not have either of those.
RIP Ninja!
87 Big Red 250es
83 Honda 200s
81 Honda Atc 70
(4) Suzuki ALT 50's
Yamaha YT 60
ok, im hoping you guys can save me from buying a new rear axle. how would i fix stripped threads on the end of the axle??
