Results 1 to 12 of 12
Thread: 300r air cooled build, need some help
    WI
    128
    I'm building a 1981 ATC 300r but I need some help...
    I was able to find:
    • 300r Hondaline big bore cylinder
    • Sleeve & piston for the 300r
    • Exhaust
    • 38mm PWK flat slide carb
    Got it assembled, but...
    • The rubber boot that connects the carb to the reed cage is far too small. Where can I get a larger one? Will one off a newer 85/86 work? The OD of the carb on the intake side is ~46mm
    • Where should I start jetting? I have a bad habit of running 2 strokes too lean and don't want to make that mistake with this build.
    • Why does my damn swingarm keep cracking? I've welded it but it just cracked around the weld...
    Stock carb jetting: 50/165
    PWK carb jetting: 55/160
    I'm hoping taking it out this weekend
    Pics:
    Frame
    Engine
    PWK vs Stock
    Running lean
    Not gonna happen
    1985 Honda 350x - Powroll 430 Kit & Lots more
    1984 Yamaha YZ490 - All the 2-stroke goodies
    Homemade "Trike"
    If your swing arm won't stay together, it may be because of inferior welds. That's not always the case though. Sometimes it doesn't matter who welds the break or how. If it's a spot that's susceptible to breakage, it just may not hold.
    WI
    128
    That's entirely possible, I tried to mig it where it cracked and it was hard to get the industrial sized welder I was working on to go low enough not to burn through.
    I thought I remembered something about these early model 250r swing arms cracking, and wondered if there was a solution (maybe its just a better weld).
    Homemade "Trike"
    Oct 2009
    FF, Man.
    774
    I think you need to get yourself an Fl350 intake off ebay
    My 3WW Feedback Thread:
    Salut Gilles
    WI
    128
    I found this
    http://www.3wheeler.org/vb/showthread.php?t=10112
    Which some guy thinks the 81 is the same as the 86 as far as bolt patterns so I got this:
    http://cgi.ebay.com/ebaymotors/230644554241
    because otherwise I'd have to get this:
    http://cgi.ebay.com/ebaymotors/110642356138
    which is cracked and I'm not sure if a 38mm would fit...
    or this
    http://cgi.ebay.com/ebaymotors/370527399233
    which is expensive
    Homemade "Trike"
    ontario
    1,131
    1984 110 project
    1984 125 parts bike
    1983 honda 200x
    19 85x2honda 200x
    1985 honda 250sx
    1985 honda 250es
    laidout2times is offline At The Back Of The Pack Arm chair racerFirst time rider
    Oct 2007
    SOUTH OF HEAVEN
    180
    that swingets not for the 2nd gen inless it eliminates the linkage.
    WI
    128
    I ran into an issue with the new 300 sleeve, it was too long and was leaving a 1/16" gap where the base gasket sits. I had to have the skirts on the sleeve machined down .100" (used a surface grinder).
    Now it fits up nicely.
    The machine is fully assembled, the boysen RAD cage is a bit of a tight fit because of the angle and the size of the new carb, but it will work... I hope.
    Anyway, going to start it up tomorrow and drive it around for a break-in.
    What do you guys recommend I start at for jets? Anyone with a 300r and a ~38mm carb let me know what jet sizes you are running with...
    Homemade "Trike"
    jadleybray's Avatar
    jadleybray is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Mar 2007
    oregon
    352
Name:	84 pipe 2.jpg
ID:	128338Click image for larger version.
ID:	128340Click image for larger version.
ID:	128341Click image for larger version.
Name:	84 pipe 2.jpg
ID:	128338The 81-89 250r reed cages are all the same bolt pattern. V force reeds and cage will fit the foolers. I do know that the 85-86 width swinger will fit into the 83-84 frame opening although not a direct bolt in. Pic is an 84 with my 86 swinger and rear end on it
    gotballs 250r 82's Avatar
    gotballs 250r 82 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Sep 2003
    florida
    259
    the swing arm will fit on a 82 set up you would need a 82 axel and a 82 rear disc brake to make that swing arm work it will not work for a 81 set up drum brake and axel is not the same as 82
    82 300R tricked
    02 blaster wife's
    83 suzuki 250 dirt bike
    82 300R drag monster
    2007 suzuki hayabusa sweet street bike
    jadleybray's Avatar
    Mar 2007
    oregon
    352
    Oh , good call Balls. I looked too quik and thought that was a trx swinger. Those are hard to come by for the first gen R's.
    Sep 2003
    florida
    259
Name:	r pic's 005.jpg
ID:	128438Click image for larger version.
ID:	128439ya i have one on my trail 82 R but that is not the swingarm in the first pic the drag R has one almost the same but biger and longer
    82 300R tricked
    02 blaster wife's
