Results 1 to 3 of 3
Thread: 86 200x Cam Shaft replace with??
    Wisconsin
    118
    I got a 86 200x motor with the cam shaft missing and was wondering if I could use an older 200x cam shaft instead or something else???
    Jul 2011
    International Falls, Minnesota, United States
    38
    needs to be from a 200x i beileve. i dont think others will work.
    Only an 86/87 200X cam will work. It has a roller bearing that the others don't have. If your rockers and shafts are worn, you'll need those too...........
