Results 1 to 13 of 13
Thread: A little bit of engine carnage...
    May 2009
    S.E. Michigan
    1,251
    I'm helping tear down a 250R motor for a rebuild. I find myself having to laugh at the condition of this "professionally" rebuilt motor which was recently acquired. Just a couple pics here, but I figure this is enough to get the point across:
    Last edited by wonderboy; 07-20-2011 at 05:26 PM. Reason: forgot my quotes around the word "professionally"
    - Frank
    1984 200ES Big Red
    1985 350X (x2)
    1986 350X
    1986 250SX
    1984 Auto-X
    1984 ATC70
    1985 ATC70
    Gold Hill, OR
    1,295
    Nice base gasket!
    Joker 90
    1981 Yamaha YT125
    1986 Yamaha Big Wheel 80
    1986 Kawasaki Tecate KXT500
    1987 Kawasaki KXT250B2
    2005 Yamaha YFZ450
    May 2009
    S.E. Michigan
    1,251
    Got the cases split. The crank seal you see in the picture above was rubbing on the crank. Here is what it looked like from the inside of the engine. It is sorta hard to tell from the pictures, but this thing was cocked in there by about 1/2".
    - Frank
    1984 200ES Big Red
    1985 350X (x2)
    1986 350X
    1986 250SX
    1984 Auto-X
    1984 ATC70
    1985 ATC70
    May 2011
    Foothills of the Adirondacks
    104
    good lord! whats with all the rtv where the base gasket goes??? somebody hacked that thing pretty good! cases shot?
    Quad? whats that?
    May 2009
    S.E. Michigan
    1,251
    Here is the crank and bits from the bottom end. Luckily, the case looks like it is fine. There are some nicks in the bottom, but I think they can be smoothed so as to not cause a problem. The case isn't cracked and the mating surfaces look good (well, as good as they can look being as dirty as they are.
    - Frank
    1984 200ES Big Red
    1985 350X (x2)
    1986 350X
    1986 250SX
    1984 Auto-X
    1984 ATC70
    1985 ATC70
    May 2011
    eden,ny
    3,481
    i'm not too well versed on honda engines or any other that has them sleeve cover deals over the counter weights. i have worked on alot of 2 smoke engines and have never seen that.what are they and what do they do?
    Grand Rapids, MI
    522
    Wait a second... did that engine come the bcredneck stable?
    Gunter glieben glauchen globen
    The Good:
    1985 1/2 Tri-Z - Daily Rider - Pretty much stock ( wink )
    1985 1/2 Tri-Z - Custom Black & Gold, Top mount plastic tank, custom 3D printed airbox, Banshee shock
    1985 Tri-Z - Rider restore in process
    The Bad:
    1988 TRX250R with 86 ATC 250R Motor and Swinger - Screamer!
    The Ugly:
    1993-ish Banshee / 2003 Motor by VSR in Belding, MI - Duner Fun!!
    2000-ish Banshee / Motor by RDZ Racing in Fowlerville, MI - Another Duner!
    Sep 2005
    MICHIGAN
    2,027
    Dude....that's trued and welded, what you talkin about?
    86 T3
    84 T3
    86 KX250
    May 2009
    S.E. Michigan
    1,251
    I'm not sure what those "covers" do either, or why the crank is designed the way it is. It is funny, I always just thought they were solid counterweights, but these are way more complex than I expected. This crank definitely took some serious abuse. I figure it had to be on a previous motor failure, since the piston is all intact (not good, but all in one piece).
    The machine wasn't purchased from a board member (that I'm aware of anyway).
    Last edited by wonderboy; 07-20-2011 at 09:21 PM. Reason: clarified piston condition
    - Frank
    1984 200ES Big Red
    1985 350X (x2)
    1986 350X
    1986 250SX
    1984 Auto-X
    1984 ATC70
    1985 ATC70
    May 2011
    eden,ny
    3,481
    after looking at the pics again i am willing to guess that them sleeve deals are for vibration dampening. anyone know? I have never worked on an r engine but will be good to know when I do
    The R cranks have them and they normally are not an issue. I do not know there function, I just believe it's how they are assembled. RTV and improperly installed seals are though............
    God, what a sh!t arse "professionally" built motor.
    May 2009
    S.E. Michigan
    1,251
    My thoughts, exactly!
    This is one of those situations that reinforces my attitude of wanting to do repairs myself. The engine was this way when purchased, and I know that crappy shops are probably the exception, but I really don't trust many places to do work for me unless I've seen other things they've done.
    On the bright side, when this motor is all back together, I'll know EXACTLY what's in it.
    - Frank
    1984 200ES Big Red
    1985 350X (x2)
    1986 350X
    1986 250SX
    1984 Auto-X
    1984 ATC70
    1985 ATC70
    Aug 2004
    Cedar City, Utah
    474
    As far as I know the honda crank halves are counterweighted instead of full circle, and honda presses the the "tin cans" over them to reduce crankcase volume. HH
