need info
Ok gentleman I have figured out im the proud owner of a 1982 185s atc thanks to the guys that responded to my post earlier, I have a new question my trike did not have the smallchain sprocket on it, I ordered the sprocket but what holds it on? ? A snap ring or sumthing?? Im ordering parts while im at work in louisiana when I go home to florida in a few weeks I want to have everything to get it running iv ordered the sprocket for the chain an 11 tooth but what holds it on the shaft??
It's very similiar to how front sprockets are still held on today. Parts 14 and 17. Part 14 goes on the end of the shaft and you turn it slightly so the holes line up for bolts 17
Rob
Thanks for the info and schematic iv tried to find an engine diagram and haven't been able to
Go to a place like http://www.motogrid.com/pages/OemParts?aribrand=HOM. Select your 185s from the drop downs on the left and you can see part breakdowns of the whole machine
Rob
Thanks so I put the sprocket on and the other piece slides on and turns and that's all that holds the sprocket on is the bolts from that piece that slides on and bolts to the sprocket right??
Im not sure, but I think there is a front sprocket cover on ebay for like 20 bucks
Yeah that's all that holds it on. That little clip and 2 bolts
Rob
I take that back, theres 5 on ebay
//ArrowChat Integreation Code
