Results 1 to 15 of 22
Thread: atc90 manual clutch??
    Oswego, IL
    1,858
    ok can somone that has done this swap please give me a list of what parts i need to get? i have the cover of the sl90 so now i need to know if i need the main shaft and the shifter shaft or what?
    1985 atc 110 for sale
    new carb
    old trike
    1985 200x
    12.1 piston
    oil cooler kit
    white bors cam
    super trapp exhaust
    uni clamp on air filter
    350x front end
    Oswego, IL
    1,858
    and what clutch cable do i get
    new carb
    old trike
    1985 200x
    12.1 piston
    oil cooler kit
    white bors cam
    super trapp exhaust
    350x front end
    6,793
    6,793
    1969 honda sl90 .
    Quote Originally Posted by vartiak15 View Post
    Oswego, IL
    1,858
    okay so i need ansl90 complete clutch basket with the internals and the main tranny shaft, do i need the shifter shaft from the sl90 too i didnt see that on the post so im guessing i can use my atc90 shifter shaft?
    new carb
    old trike
    1985 200x
    12.1 piston
    oil cooler kit
    white bors cam
    super trapp exhaust
    350x front end
    Oswego, IL
    1,858
    o i see it now i can use the stock one ill just have to cut it down right?
    new carb
    old trike
    1985 200x
    12.1 piston
    oil cooler kit
    white bors cam
    super trapp exhaust
    350x front end
    Oswego, IL
    1,858
    so i would cut it basically where the spline part ends
    new carb
    old trike
    1985 200x
    12.1 piston
    oil cooler kit
    white bors cam
    super trapp exhaust
    350x front end
    Oswego, IL
    1,858
    here is a pic of what im asking
    new carb
    old trike
    1985 200x
    12.1 piston
    oil cooler kit
    white bors cam
    super trapp exhaust
    350x front end
    6,793
    Slide the shift shaft into your case and mark it flush with the case . Thats the cut spot not at the splines , its almost at the link arm .
    Oswego, IL
    1,858
    i didnt get my case yet, its on the way. are you talking like right in the middle of the splines
    new carb
    old trike
    1985 200x
    12.1 piston
    oil cooler kit
    white bors cam
    super trapp exhaust
    350x front end
    Oswego, IL
    1,858
    never mind i rear that wrong sry i got ya know so now i just need a clutch off the sl90 and the main trans shaft
    new carb
    old trike
    1985 200x
    12.1 piston
    oil cooler kit
    white bors cam
    super trapp exhaust
    350x front end
    Oswego, IL
    1,858
    do i need the main shaft or the counter shaft shortline?
    http://cgi.ebay.com/ebaymotors/HONDA...item5adfffb001
    is that the one?
    new carb
    old trike
    1985 200x
    12.1 piston
    oil cooler kit
    white bors cam
    super trapp exhaust
    350x front end
    6,793
    Counter shaft is what your looking for and the one in that ebay auction is the wrong part , it's a counter shaft but the wrong counter shaft .
    is that the one?
    tblumer's Avatar
    tblumer is offline At The Back Of The Pack Arm chair racerFirst time rider
    Nov 2009
    Liverpool NY
    225
    Sorry to dredge this thread up,
    Can I use S90 parts for this conversion? I have a S90 motor that I rebuilt a while back for a VanTech framed S90 that I've been hanging onto. Also I assume the top ends are interchangeable? I had the cylinder bored and installed the DrATV +4mm piston and his "hot" cam, I'd like to use those too if possible. This is on a 74 ATC90 motor.
    84 ATC 70 w/88 (for the kids)
    85 Yamaha YTM200 (Protek suspension / Tecate forks)
    74 Joker frame ATC 90 w/ 110 cdi
    71 Honda Z50AK1 Mini Trail w/117cc stroker
    CRF50 stunter w/117cc stroker
    08 Yamaha WR250X
    My feedback:
    http://www.3wheelerworld.com/showthr...89#post1080789
    6,793
    Yep it will work just make sure the crank spacer/washer between the clutch and the crank is correct so the clutch arm is in the correct position . Do a test fit to make sure you have it correct .
    Quote Originally Posted by tblumer View Post
