Thread: HELP!!! What 4x110 hubs can I swap to on my 1984 200ES Big Red??????????
    Jul 2011
    Chattanooga TN
    48
    First let me say, YES, I looked through the old post on this site using the search feature (very nice indeed). I have a 1984 200ES Big Red that I want to swap the rear hubs to a 4x110 bolt pattern. I found a post that said "its a 24 spline and that hubs off of 400EX, 300EX, 250X & 450R should fit right on". Can anyone confirm this? If this is correct has anyone done this? If so which did you use? Did it add any overall width? Are there other hubs that will fit? Should I look for used or go buy new? Thanks!!!!!
    Aug 2010
    Southern Oregon Coast
    932
    In a pile of bikes I got last fall there was a set of 4x110 hubs. I'm pretty sure they were 200x. Anyway, they fit in the 200ES. Maybe gained 1/2" total width.
    Jul 2011
    Chattanooga TN
    48
    Cool, I will also check into those. Thanks For The Info!!
    1,736
    i put 400ex hubs on my atc110, works great and added a fair amount of width.
