Results 1 to 15 of 24
Thread: Check out my "bad bore"
    ctbale is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    anchorage alaska
    289
    First off, I cant even believe I put this thing together, it was like this after I got the cyl back from the "machinist" Its got about 60 to 90 mins on the new piston/bore, it sounded like crap and after 3 oil changes there was still gobs of metal in the oil. I am boned on the cyl, I went to 3rd over and I dont think .010 will clean it out for a 4th over piston, I am so pissed!!!!!!!!!!!!!! I had a new vesrah rod kit put in by the same guy, I even printed the manual showing that any tooth needs to be lined up with the woodruf slot, it was not even close! Did I mention I am sooo Pissed!!!!!!!!!!!!!!!!!!
    I have a worn regular 200 cyl on standard, less fins, but I am in Alaska.
    check out this video, I noticed that I got the piston 180 degree off, should not matter for the vid, it was in correct when installed.
    http://www.youtube.com/watch?v=2Ws7RwHU2lk
    Attached Thumbnails Attached Thumbnails DSCF0156 (Large).JPG   DSCF0152 (Large).JPG   DSCF0153 (Large).JPG   DSCF0155 (Large).JPG   DSCF0154 (Large).JPG
    anchorage alaska
    289
    more pictures
    Here are more pics
    Attached Thumbnails Attached Thumbnails DSCF0159 (Large).JPG   DSCF0157 (Large).JPG   DSCF0161 (Large).JPG   DSCF0160 (Large).JPG   DSCF0162 (Large).JPG
    WilliamJ's Avatar
    WilliamJ is offline At The Back Of The Pack Arm chair racerFirst time rider
    Apr 2010
    Poole, England
    157
    Hard to tell looking at the photos but doesn't look like 5 thou of damage in the bore. It may be usable.
    Are you saying the rod has been fitted wrong and caused it? Are the clearances wrong? Were the rings badly fitted / wrong size?
    You need a different machine shop to measure and inspect it properly to see if the cylinder is usable.
    Bill
    Custodian of:-
    85 Tri Z - need rear plastics to go with Mosh seat cover
    83 200x - engine being rebuilt but lodging with a friend
    85 250r - also lodging with a friend until I have a new shed
    ....and a different kind of Z
    6,811
    Is that slop in the piston with the rings installed in your video ? What is the ring gap measuring at ?
    anchorage alaska
    289
    thats just the piston in the cyl, no rings, i will make a vid with it with all 5 rings install too. end gap of the two compression rings using the piston to square them up is at .013' to .014' thru the entire stroke, not great but not bad? My compression was 170 to 175. The problem is a LOUD scraping sound when its running, I have swapped out cams, no help. Today with the cyl off I looped the cam chain around my thumb and by holding the top of the rod spun the crank very fast, got oil up the oil port, and everything was silent and smooth as silk. Wrist pin looks good too. Its a shindy piston, at the skirt front to back in the bore, its pretty tight. Measuring the piston, the diff from front to back and left to right is .016" at the skirt. and my wisco is only .009" Forged vs cast? I have a fair amount of experience with honda and yamaha engines and this has me stumped. How does that cyl look to you guys for aprox 90mins of run time?
    6,811
    Compression is good and the ring gap is acceptable and I see no blow by on the piston but the bright spots/scrapes in your cylinder say to me the piston is egg shaped and possibly no good , that would be my guess . How does the crank look when you rotate it ? does it spin true and straight ?
    anchorage alaska
    289
    when the vesrah rod kit was installed, when I got it back, one of the installed thrust washers was bent, like a potato chip. there was a gap, but you could see the washer had a wave in it. The rod had resistance to rotation, the guy said it came like that and tried to straighten it. I would have just re-used one of the old ones. Could that resistance be pushing the piston forward against the cyl wall? Its loosened up after running it, but the rod dont flop around like they usually do!
    Your machinist suks...............
    6,811
    Sounds like he didn't get the rod pin right the first time and had to press it out and start over which will bend the fragile washers, the bearing might be compromised as well .
    Quote Originally Posted by ctbale View Post
    anchorage alaska
    289
    come-on DC!!, you more experienced guys are supposed to tell me something I dont already know! LOL
    Getting burnt out on my 200x, I think I will go putt around on my 70 or my 90 and come up with a plan, my dog likes those bikes better anyway.
    anchorage alaska
    289
    On a new rod, with a good intallation, will there be slight resistance like on a new sealed wheel bearing, or will it "flop" from its own weight? Just checked the side to side, there is .008" gap
    anchorage alaska
    289
    Thinking hard about 10.25:1 wiseco, next size up.
    6,811
    Should spin freely with no resistance if done correcty .
    ^ Exactly, it's a needle bearing with some side to side clearance. No resistance or play should be felt............
    anchorage alaska
    289
    S#!T!! Now its a "due over" on the crank and the piston/cyl !!
