Results 1 to 3 of 3
Thread: 81-83 atc200 fender bolts
    Jul 2011
    Mid South
    98
    Where can i find the proper fender hardware for my 82 atc200 restoration project? I assume I need some 10mm head bolts,collars,and maybe grommets but don't know exactly what I need because the fenders are currently held on with a mix of philips head screws and everything else. They don't have to be factory because I don't want to pay 10$ a piece.
    82 atc110
    82 atc200
    83 atc185s
    Whats old is new.
    Scootertrash's Avatar
    In the sticks
    4,638
    Here is the fiche, with prices, for your rear fender:
    http://www.servicehondapsn.com/fiche...1982&fveh=2794
    You may be able to find the parts you need at a well supplied hardware store, or you could try Mcmaster-Carr:
    http://www.mcmaster.com/#
    Problem is you will need at least one correct factory part for each part you need to match up
    Collar (12 needed)
    5X18 screw (8 needed)
    6X16 bolt/washer (10 needed) I'm not sure if they mean a bolt AND washer or a flange head bolt that has kind of a built in washer
    6X16 screw/washer (2 needed) see above about the "washer" part
    5mm flange nut (8 needed)
    Jul 2011
    Mid South
    98
    I have all of the mudflap mounting hardware and can match up new ones at the supply store. I just need the bolts and stuff that hold on the fender itself. It looks like a need
    6X16 bolt/washer (10 needed) w/ collars for the top strip
    6X16 screw/washer (2 needed) w/collars for the sides
    If the 6x16 side screws are the same thread pitch as the 6x16 bolts on the rest of the fender I would like to just go with all bolts.They look like the same thing with different heads and use the same collar.
    I haven't looked at the front fender hardware yet but I know there are only 4 bolts. I don't know if I have to proper washers or collars yet.
    If its only a dollar or two a bolt I will just order the whole set online. Is hondapartswarehouse a good place?
    82 atc110
    82 atc200
    83 atc185s
    Whats old is new.
