Right out of the top of the engine where? Where the cylinder meets the engine case? That's the lower cylinder gasket. Right where the 2 halves of the engine meet together? I don't think there's even a gasket there. Seals are generally where the oil sits. Both ends of your crankshaft and the gearshift lever should be where your seals are. Anywhere else is either gaskets or where metal to metal is bolted together.
Nicholson 500x (Project)
Nicholson 185s
PK Racing Suspension 70
A+ Inc Suspension 70
AWS Aluminum 90 frame
