Results 1 to 12 of 12
Thread: starting issues
    jordan_muirhead's Avatar
    jordan_muirhead is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jan 2011
    Monticello, Arkansas
    316
    starting issues
    not sure if its getting spark, it was weird, pulled it this morning, fired right up....let it idle, didt mess with the choke or give it any gas, was letting it warm up, after about a minute...it died...and has since to restart...any ideas? i thought this was odd
    "A common mistake people make when trying to design something completely foolproof is to underestimate the ingenuity of complete fools"
    "Trikes Owned-1983 Honda 185S- eBay 200x carb, and uni filter-Sold"
    1986 Honda Big Red 250ES
    I bleed Honda Red You Should Too
    Three Wheels Are Better Than Four
    R.I.P ROOSTER-Dustin Ray Ferguson(9-20-89)-(9-22-08)
    R.I.P Jesse Ray Cash(6-17-93)-(12-14-09)
    O.C., Oregon
    921
    Start with cleaning your carb, could be junk in the float bowl and it coulda clogged up your jets..
    1978 ATC70 w/ Piranha 140cc
    2017 YZ 250x- Braap
    Jan 2011
    316
    i took it off two days ago and it was as clean as a whistle, ive only run about 5 tanks through it and i got it new, and it has fresh 93 in it now
    O.C., Oregon
    921
    You check your plug? Air filter? Petcock? Just a few things that are easy to overlook and can have a big difference in the way a bike runs..
    2017 YZ 250x- Braap
    Jan 2011
    316
    plug should begood few months old, filter is nice and clean, will check the petcock in a little bit, I drained the bowl too..not sure what else to do
    O.C., Oregon
    921
    I'd still check it, could be really rich and fouled out..
    2017 YZ 250x- Braap
    Jan 2011
    316
    gunna check when I can find a socket lol. mine is mia, so itll be a little bit before I can check it, hope its just the plug
    Jan 2011
    316
    could my air/ fuel scew have anything to do with this?
    Jan 2011
    316
    could this be the culprit?
    guess you were right roostmaster
    Jan 2011
    316
    I cleaned the plug with the .22 wire brush from my gun cleaning kit, and some 800grit sandpaper, came out like new almost, also I was wondering what the gap is supposed to be on my 185s, its running good now, but ive never gapped the plug
    Nubbinz is offline At The Back Of The Pack Arm chair racerFirst time rider
    Winchester, VA
    171
    .7, chief. although every ngk ive put in mine was already at .7. and lol@ you wire brushing your plug, i scrape mine with a screw driver wipe em off with a rag and my trike runs like new, in 4 years ive replaced the plug in my 185s once, and that was because it backfired and killed the plug.
    Jan 2011
    316
    this was a new plug a few months ago, but I hit it with tht .22 brush and scraper paper and it looked pretty new lol, thanks for the info too
