Results 1 to 3 of 3
Thread: 81-83 atc200 rim assembly
    Jul 2011
    Mid South
    98
    81-82 actually
    What is #10 patch/rim support do and is it really needed. They are 30$ a piece and im missing all 4 of them!
    Also is #16 some type of o-ring that goes between the two halves of the rim to seal the air in? Can you unbolt the rim into two pieces to mount a tire?
    On the back rims does it matter does it matter which side is facing out ?
    82 atc110
    82 atc200
    83 atc185s
    Whats old is new.
    6,804
    Yes those patch rings are needed . They keep the rim from bending and cracking . With out using them the rim might bend and wont seal the O ring .
    The large O ring is to seal the two rim halves together .
    PAPA250r is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Feb 2009
    greentown PA
    389
    Hummmmmm i bet thats why my 2 piece rims always leak never had the rings on em
    84 200s almost done
    84 atc 70 project
