Results 1 to 3 of 3
Thread: oil cooled 90/110 questions
    Oswego, IL
    1,858
    does anyone have a picture of where the lines go into the motor? i am wanting to oil cool my motor in my 90 project and i couldnt find any pics on here, well none of where the lines go in. Any help is wanted, or if anyone has some old mag clips that would help out too! thanks again Jim
    1985 atc 110 for sale
    new carb
    old trike
    1985 200x
    12.1 piston
    oil cooler kit
    white bors cam
    super trapp exhaust
    uni clamp on air filter
    350x front end
    Baltimore, MD
    6,088
    If you look at the lower clutch side cover, you will see a part sticking out towards the front that is flat along the bottom and has a plug pressed into it. That is the oil line near the oil pump. You have to drill 3 holes and tap for 2 fittings for the supply and return and one threaded plug to divide that oil passageway in 2. I have a picture in a thread of it somewhere on here and it gives the drill size, the tap size and the shows where to drill.
    Nicholson 500x (Project)
    Nicholson 185s
    PK Racing Suspension 70
    A+ Inc Suspension 70
    AWS Aluminum 90 frame
    Baltimore, MD
    6,088
    Nicholson 185s
