Results 1 to 9 of 9
Thread: 200x
    jordan_muirhead's Avatar
    jordan_muirhead is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jan 2011
    Monticello, Arkansas
    316
    200x
    I was wondering if a 200x that is running for 400 bucks is a good deal, my buddy knows where one is and im gunna try to get it, anything I should look for?
    Sep 2007
    100mi west of Chicago
    3,582
    Hard to say without seeing pics. $400 for a first gen is about average. Try kick starting it and see if the kicker gears slip
    Rob
    Jan 2011
    316
    so if it doesnt slip im good? my buddy said it runs great tho, im waitin on him to take pics cuz its a good 30 minutes from me
    but if I make it an auto x I dont have to worry about the kickstart as much right?
    Freedom Township, MI
    642
    Quote Originally Posted by jordan_muirhead View Post
    Correct, an auto x traditionally uses either a 200s or 185 engine; both are pull start.
    Current Trikes:
    85 350x
    P3 (x2)
    Quads:
    2003 Polaris Predator 500
    1988 Yamaha Warrior
    2003 Polaris Predator 90
    Previous Trikes:
    84 Honda 110 (parts)
    85 Honda 110
    85 Honda 200x
    87 Honda 200x
    85 Honda 250sx
    KX 80 Trike conversion
    Gone and missed:
    Jan 2011
    316
    I was pretty sure, ive already looked into it, my only trike is a 185s lol, but how hard is it to fix the (slippage) if it happens to exist, because I wouldnt start on making it an auto x for a little while, and id still wanna rideit....i guess I could always pushstart it right? thanks for the help
    NEPA
    7,051
    You can still coast start it yes. To fix them properly. You have to split the cases,completely. So,you need some time and knowledge. But,if they're not slipping. You will be looking for the usual,,,,,,deeep breath,,,Loose or leaky forks,,bad or loose,,,swingarm,rear axle,fr wheel and head bearings. Loose hubs on the splines,smoking,ticking,ratting,slipping clutch. Bad brakes,pads or sticky slide pins,bad or stuck hydraulics,tires,plastic seat. Rusty tank? Idles good? Lights working? Air filter crumbled in the bottom of the air box. Shocks working correctly. Axle straight? Frame cracked or welded? If most checks out,,,that's a LOT of machine for $350-$400!
    Jan 2011
    316
    well, even if it has a few problem, I plan on replacing all bearings, brakes....but it would be cheaper to buy the whole trike, you dont see alot of trikes in this area, he doesnt have it up for sale, but would let it go for 400 he said, which give mes time to get things in order
    how do you tell if forks are leaky or loose how do you fix this? seals, is this expensive?
    Sep 2007
    3,582
    If the forks are leaking you will be able to tell, they make a mess. And they make a squishing sound when you compress them.
    Rob
    Jan 2011
    316
    oh, well, that seems simple enough...would seals fix this?
    "A common mistake people make when trying to design something completely foolproof is to underestimate the ingenuity of complete fools"
    "Trikes Owned-1983 Honda 185S- eBay 200x carb, and uni filter-Sold"
    1986 Honda Big Red 250ES
    I bleed Honda Red You Should Too
    Three Wheels Are Better Than Four
    R.I.P ROOSTER-Dustin Ray Ferguson(9-20-89)-(9-22-08)
    R.I.P Jesse Ray Cash(6-17-93)-(12-14-09)
