Results 1 to 15 of 16
Thread: compresion 90lbs what should i do?
    Watertown, New York 13601
    3,382
    I took my tri z to the yamaha shop to get the carb cleaned and they did a compresion check and it runnong 90lbs. They said it should be running 120-125lbs. they want like $750 to do watever it takes to fix it. The bike runs fine and fast. What should i do? will it hurt the bike if i keep riding it and why is it so much?
    1985 YAMAHA TRI-Z 250 sold
    2006 YFZ 450
    Ashland City, TN
    2,576
    They're full of trailprotrailprotrailprotrailpro. If you only had 90 psi of compression, I doubt it would start. Anybody wanna back me up on that? For sure, it would be REALLY hard to start. How easy does it start? And what they tell you of 120-125 psi, they're full of it. The correct PSI is 160-190 psi. I doubt it will hurt the bike to run it. 750 dollars to fix it is a ridiculous price. If you do it yourself you can do it for about 200 bucks.
    81 dollars for piston kit(guy off ebay will sell to anybody), average 50 dollar bore price, 50 dollar gasket kit, 15 DOLLARS for a new wristpin bearing, thats a total of 196 dollars. Sure beats the shop ripping you off and any idiot can rebuild a 2-stroke, just make sure to drain the coolant first and torque down bolts to spex.
    Trikes:
    1973 Honda ATC70-orange!
    (2)1985 ATC70
    1985 Big Red 250
    1985 250R
    3,382
    they are cleaning the carb becuse it use to flood easy. but the bike has lots of power. i don't know what they mean it needs to be rebuilt. it runs fine for me besides the flooding.
    2006 YFZ 450
    3,382
    to do a compression check do you have to have the bike running?
    2006 YFZ 450
    potsdam NY (upstate)
    1,437
    no
    you start the engine let it wrm up then shut it off and there is a tool with a gage that screws into the spark plug whole and u kik the engine over and it will tell you how much psi u have. you can also do it with the engine cold but u get a better eading with it warmed up first.
    looking for a TRI-Z 250 to restore at the moment
    LONG LIVE THE 2 STROKES !!!
    3,382
    but if they said it was only getting 90lbs of compression what would it run like? it runs fine for me.
    2006 YFZ 450
    3,382
    can i get that tool anywere? and how much? I want to check it myself. I think they are trying to rip me off $700.
    2006 YFZ 450
    May 2002
    Cortland, NY
    1,195
    If it only has low compression can't you just put a new pistion and rings in it? I guess unless it really needs a bore. twgranger the dealer is trying to rip you off hard core! If the bike runs fine and starts right up just ride it.
    http://photos.yahoo.com/dynofox250 (TF 03 pic's)
    Trikes: Restored '86 ATC 250r, original and mint '83 185s
    Quad: '86 TRX 250r
    Sled: Rev X 800ho mod
    Bike: '00 ZRX 1100
    TF '03 and '05 Survivor
    3,382
    Im going to see how it starts after they clean the carb. It use to start hard with it flooding so easy.
    2006 YFZ 450
    bbechtel16 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Halifax, PA
    400
    Quote Originally Posted by twgranger
    We bought one at Sears once. That's right we. Me and 2 of my friends went together on a $24 compression tester lol! I was disappointed to find they didn't include a small enough adaptor to make it work on the SX. But it does work on the 250R so I'd guess it would work on the Tri-Z too?
    -'86 ATC 250SX: No longer mine... Complete 350X front end, Corbra Megaphone system, 350X carb with UNI dual stage foam & outerwear bolted driectly up, Powroll/Rocky 260cc bore 10.5 to 1 compression piston.
    Rittman, Ohio
    6,276
    Sign of low compression are , it will get progressively harder to start, youll start to lose low end power (top end will still seem fine), and your plugs will start to look like its running richer.
    There is no way to know whether it needs just a hone and new rings, or if it needs a bore job, without taking the top end off and taking some cylinder measurements.
    Beware anyone who quotes a repair price on something they have not disassembled. Houdini doesnt do mechanical work.
    slippy4 is offline Just Too Addicted Arm chair racerJust too addicted
    May 2003
    556
    yes, fleetfarm or any car place should have them. i highly doubt it would even run as my old YTM 125 had 90psi and it would shut off after about 10 min of riding ( normal for the 125 is about 135) My Z has about 175psi so 90psi would deff. not be able to start (at least not by kicking it over)
    85 Tri-z
    38mm Flatslide
    Boysen Power Reeds
    DG Pipe and Silencer
    Bored 1.25mm over
    Wiesco Pistion and Rings
    K&N Clamp on Filter
    Compleating Restoration
    1,437
    dont let the shop fix it
    if it does need to be fixed this is how much it cost me here.
    bore: 20$
    piston and rings: 90$
    gasket kit 15$
    labor: free any person can rebuild a 2 smoke they are the easyest thing in the world.
    thats a total of 125$$$ dont u dare pay 700 they are trying to rip you very badly even if they did the work its only like a 2 hore job, i could do it in an hour but i take my time and make shure its done right. thats fing highway robbery.
    Sep 2003
    129
    If it only has 90psi , it would be hard, if not impossible to start! I also agree w Timsr in that it will lose it torque (low end), and it will run rich-be hard to start. I definatly wouldn't make the statement, that any idiot can rebuild a 2-stroke though.
    84 200x (modded)
    82-84 250r (basket case)
    80 110 (project)
    95 thundercat
    84 indy 650
    When in doubt: STAND ON IT!!!!
    Rittman, Ohio
    6,276
    Yeah, Ive seen some two strokes that were rebuilt by idiots!
