Results 1 to 11 of 11
Thread: gasket name?
    Watertown, New York 13601
    3,382
    gasket name?
    what is the name of the gasket that goes on the bottom of the cylinder? and were could i get one? Im not going back to my yamaha dealer ship because they messed my wheeler up! what is involved in changing that gasket?
    1985 YAMAHA TRI-Z 250 sold
    2006 YFZ 450
    Lots_Of_Nothing's Avatar
    Upstate NY
    2,665
    it is called a "base gasket" you can order one from www.bikebandit.com , or a dealer..........to install the base gasket you have to remove the cylinder off from the piston, remove the exhaust so you can take the cylinder off, and take the carb off so you can removed the cylinder......basically its just removing everything that is bolted to the cylinder, taking the cylinder off, and the gasket goes where the cylinder bolts to the base
    3,382
    i cant find it at bikebandit. what is it under?
    2006 YFZ 450
    3,382
    i found it. is there any other gaskets ill need to change the base gasket? from taking it apart.
    2006 YFZ 450
    Upstate NY
    2,665
    well, if your base gasket is bad, your other gaskets are probly due for a change also, if i was you i would buy a whole new top-end gasket kit
    3,382
    is there anything i should be aware off while taking the cylinder off? I dont want to mess the piston up.
    2006 YFZ 450
    Upstate NY
    2,665
    not really, just pull the cylinder straight off, and dont turn it, dont force it either, if it gets jammed or soemthing, put it back on and try again, if you force something you could mess up your piston rings, also when re-installing make sure your rings are in line up with the ring stops, and you put the cylinder on straight and dont spin it
    3,382
    well i just order new top end gasket set from dennis kirk. When i put it back together how tight should the bolts be on the cylinder?
    2006 YFZ 450
    Upstate NY
    2,665
    for mine, i just tighten them till they are good and tight, but not tight enough to strip them, i know some people use a torque wrench to get the nuts to a specified tightness, i have never done this, and have never had any problems, although somone may have the torque settings for you, i dont... and make sure when you are taking off and putting on the head/cylinder you tighten/loosen the nuts in a criss-cross patern so that you dont warp the parts, and also, use a knife to scrape off all the old gasket if there is any residue left on parts from the gaskets
    3,382
    I decided the hell with it, ive owned the tri z for almost a month now since i have to replace the base gasket i am having the piston done while its apart. I have no clue if its ever been replaced but what the hell.
    2006 YFZ 450
    there you go better safe than sorry.i just got a 84 t3 and i am doing the engine over this way i know i will not have any prolbems or have to repair any previous damage. good luck!!!!!!!!!!!
    85 tecate original, stock
    for sale :84 tecate complete,8inch+swingarm, complete rebuilt engine,dg type2 , ,douglas aluminum rims with realtors, new stator and fly wheel.
    70 something hodoka ace 100
    84 lt185
