I have a 79 ATC 110 with Points. I was wondering if you are able to use The two small Springs in the timing advancers from a CDI Advancer on a Points advancer...? they look the same???
Anyone... ?
it would be a matter of the spring rate heres a calculator i have used in the past for chevy mechanical advance distributors
[URL="httphttp://www.efunda.com/designstandards/springs/calc_comp_Krange.cfm"]
hope it helps
