Any one know of any other rear shocks that would fit on a 86 200x?
i made a thread about this about 3 years ago.. try a search... i don't think their were any direct replacements...
86 200x
72? US90
79 ATC70
83 ATC70
84 ATC70
wow
I'd be tempted to see if any part numbers may match up.
like from a 350x might be the same.
but surely someone on here has a trick suggestion.
Are you looking for something special?
different rebound rate?
one that simply doesn't leak?
My local autoparts can actually match shocks up according to
length of travel, max, min and then you get to pick your mounts.
Who knows, it might be the same as a ford 4wd steering damper.
Had gas shocks been invented by the early 80's?
Maybe you don';t need the coil over unless you like the adjustability feature.
Then again, my koni and kyb gassers are adjustable.
I put a Works Performance rear shock on my 86. They can set it up however you want. They are bucks though.
