Thread: 86 250R no rear brakes - sometimes.
    Micahdogg's Avatar
    Micahdogg is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Dec 2007
    Illinois
    378
    I was riding the R around a very tight backyard track and I was on the back brakes quite a bit. After about 15 laps the rear lever just went straight down and I had nothing. Figured a brake line let go so I limped it over to the garage and let it sit. I didn't notice any fluid dripping, but after about 15 minutes I went over to check it and it was working again? WTF?
    So I popped the reservoir and it was low. I added some fluid, little too much as the reservoir cap pushed some out. I even checked the bleeder and it shot out two good streams of fluid. Figured all was good, went back out and after about 15 laps the rear brake went to the floor again. WTF?
    So I limp it to the garage - let it sit and now it has some drips from the swing arm skid plate. I can't tell if it's from the top of the reservoir where I overfilled it a little or from somwhere else though. But what would cause the brake to not work when it gets hot, but then it would come back when it cools down?!?!?
    (if you click this stuff, you will see pictures of this stuff)
    2001 Indian Scout
    2011 KTM 250SX
    1986 ATC250R
    1989 Thunderbird SuperCoupe
    2006 F150 Crew
    Oct 2009
    lindenwold new jersey
    890
    pads... still have some on there? pistons sticking
    LIVE IN EAST PA. OR NEW JERSEY THEN CHECK THIS OUT www.njdirtriders.com SUPPORT LOCAL RIDING WITH US
    Micahdogg's Avatar
    Dec 2007
    Illinois
    378
    So as the brakes get hotter, the lines swell and piston has to move further out....then it gets stuck. Hmmm. Is this a theory or does it actually happen on these? I'll have to check the pad thickness when I get home.
    2001 Indian Scout
    2011 KTM 250SX
    1986 ATC250R
    2006 F150 Crew
    Sarnia, Ontario, Canada
    3,415
    Water in the brake system!!..it will settle to the lowest point(caliper) then as it gets hot it boils to vapour and as we all know air causes spongy brake pedal. It cools and turns back to liquid, pedal comes back!!
    Drain and flush the entire system with clean fluid..also clean any brake fluid up when you are done. It eats paint!!
    25 year old brake fluid is sure to have condensation in it!!!
    Current toys..
    1986 Honda 350X..trail bomb!
    Current non-trike toys:
    1990 Honda TRX300FW
    1995 Seadoo GTX
    1998 Polaris Touring 500
    1998 Club Car (electric)
