just noticed this today, was never wet before..
Theirs a large O ring seal around that flywheel cover , its best to replace it but in a pinch you can remove it clean it up and install it in reverse and it will usually fix the issue for a bit . Also a light weight oil in the summer months might make it seep .
thanks i'll look into the seal, its past and oil change anyway
