Here's an idea. Check the tank for rust. Take the petcock off the tank and make sure it's not stopped up, not getting gas to the carb MIGHT be a bit of an issue. Or take a flathead and unscrew the overflow screw and see if gas is going through the carb, it has to be kinda steady, a few drops means the petcock or tank.
Also, make sure the idle is turned up, too low of an idle will also cause starting problems.
