Results 1 to 8 of 8
Thread: 1985 Honda 200x kick stater question
    Canada,barrie,Ontairo
    229
    Thumbs down 1985 Honda 200x kick stater question
    so i bought a 200x kickstart was skipping when i would kick it over to start it. kick start return's perfect.
    so i tore the motor apart today to find there nothing worng with the return spring or the rachet gear spring works good to.
    when i split the crank case and looked at the kicker stuff. Looked like the gear rachet wasn't siting fulley on the gear rachet bolt on the back of the crank case would this cause it not to work cus all the kick starter gear's etc... looks in good working shape
    the gear rachet bolt wasnt all the way siting on the on the gear rachet it was on the gear rachet still but not sitting where it should be
    Pacific NW
    4,255
    Sorta hard to picture for me but the 'search' key has been working great lately
    and the manuals are free in the 'world class help' section.
    I DO know there is tons of info about x kickers on here.
    Looks like said 'skipping'. I thought it said slipping.
    Something that sounds like 'one way clutch' comes to mind.
    ...so you push down as if to start it and it doesn't really want to grab predictably every time?
    If I'm hearing you right.
    I'd hit
    'x kick start', with the search key and see what happens.
    If it's a positioning error, lord knows who was in there doing what and lost a spacer or thrust washer.
    bikebandit.com has some exploded diagrams of almost everything so maybe you can get an idea if everything is actually in there.
    6,816
    When the kicker assembly is all together in the cases it will sit straight so thats not the issue . The problem is the smaller spring that meshes the ratchet gears together is to weak . The correct fix is to buy the upgraded spring but its not avalible anymore so your next option is to back cut the ratchet teeth so they grab better and stretch the spring out so their is more tension on the ratchet set .
    Quote Originally Posted by curtis slawson View Post
    229
    so i took some picutres to show you how it looked
    this is how the gear rachet bolt was siting on the gear rachet gear wassnt sitting fully on the grove where it should be
    and wear an tear cus it wassnt sitting right.
    6,816
    I dont see any wear ? That grove in the case was machiened by honda to accept the larger 84/85 kicker gear .
    229
    so if i replace the gear rachet spring and the gears it should all be good then
    Sep 2007
    100mi west of Chicago
    3,582
    I would seriously consider cutting back the teeth now while you have it apart. It would be heartbraking if you replaced a couple parts and put it back together only to have it still slip.
    http://www.3wheelerworld.com/showthr...outions-inside!
    Rob
    229
    Quote Originally Posted by rdlsz24 View Post
    Rob
    on the progress of doing it right now lol thanks Rob
