Results 1 to 3 of 3
Thread: Bearing Carrier Question
    Jan 2008
    Willowbrook, IL
    856
    Does anyone have a trick or method they use to put new bearings into their carrier? (85 250R) Or, should I find someone with a bearing press and make sure there are no mistakes? Seems to be something simple but that's what scares me, don't want to mess that up. Let me know your thoughts and/or secrets. Thanks.
    85' Honda Big Red
    09' Yamaha YZ 250F
    2012 Polaris Sportsman 500 H.O.
    2015 Polaris RZR 570 LE/Trail Edition
    2017 Suzuki DR-Z400SM
    Pacific NW
    4,255
    R?
    Swing arm bearings are the nightmare, I think.
    Carrier? as in rear axle bearings?
    Manuals are free in the 'world class help' section
    but I've replaced bearings by freezing them
    and heating whatever they go into with a hairdryer or a lil' bit o' propang heat.
    Usually gives you a thousandths or 2 extra to weasel them in there.
    If it's as I picture it...one bearing on each side a few inches apart,
    A long bolt with the right size washers and just pull them in together towards each other by
    tightening the nut...nicely aligned, slowly and careful, might just walk themselves in.
    or
    if it's off the machine, how much would a shop charge for 5 minutes work?
    did you get the old ones out?
    did they come out easy?
    too easy?
    If you're really in tune, you may be able to fit the outer races with the correct diameter pipe
    and smack THAT with a 2x4 or deadblow, which is probably what they'll do at the shop.
    London, Ontario, Canada
    1,059
    My Rides
    -under restoration
    -Paul Turner pipe
    -+2" Westcoast
    1985 Green Tecate Sold
    My Wife's Ride
    My Kids Ride
