Results 1 to 15 of 20
Thread: 1985 vs 1987 250sx
    Feb 2006
    Middletown, Connecticut
    41
    1985 vs 1987 250sx
    Short and quick...
    Will a 87' 250sx rear axle fit a 85'?
    Thanks,
    -Rob
    ontario
    1,131
    I don't think so but I maybe wrong. I know on the 85's the rear brake drum is held in place by the hub and the 86-87 had the drum on its own then a hub on its own. I maybe wrong.
    1984 110 project
    1984 125 parts bike
    1983 honda 200x
    19 85x2honda 200x
    1985 honda 250sx
    1985 honda 250es
    Feb 2006
    41
    ...well... I'll find out when it comes in. *face palm*
    Jul 2011
    Greeneville Tn
    116
    Doesnt the 87 model have a sealed carrier. If so you wouldnt have to be as worried about getti.g water in the rearend. I think ive read that somewhere online.
    Tri-Z Pilot's Avatar
    Tri-Z Pilot is offline Check my feedback before buying from me Got the holeshot
    Central PA
    1,952
    If you have the opportunity pick up the complete 87sx rear end. They are said to have an awesome gearing setup different from the other sx's
    PastRides
    Originally Posted by atctim
    I prefer to be called a "3 wheeled American" I find the term "Trike People" very offensive and derogatory!
    SOON MY PRECIOUS!
    Feb 2006
    EC
    1,607
    Yes, the 86/87's had the sealed differential, I'm not sure what was different from the '85s, but I had my 87 through some DEEP stuff & it never had issues. The 85, on the other hand, doesn't do well in water AT ALL!! The main problem I have w/ mine is the shoes stay wet & fall off the bakings & the pin that turns the shoes outward gets locked up if I don't clean it & dry it after every water soaking,
    Triz-Pilot, I never heard the 2nd gen SX's had different gearing, I've had both & never noticed the difference. Wher'e'd you hear that?
    Jul 2011
    Greeneville Tn
    116
    So will the 87 rearend fit the 85 swinger or will you need the 87 swinger also which driveshaft will you need.
    Central PA
    1,952
    Well Gazoo whats up man? Haven't seen you since Pennsyltucky 09.
    Anyway I think it was on here there was a discussion on this, apparently the 87 sx's had a different final drive making them more 'peppy' or something.
    PastRides
    SOON MY PRECIOUS!
    Beaver Falls, PA
    2,666
    Quote Originally Posted by PerryS View Post
    The differential will swap, but that's it for rear end parts. Totally different designs. The entire swinger assembly will swap over, however... I had a whole '85 swinger on my '87.
    Jul 2011
    Greeneville Tn
    116
    I dont mean to thread jack but how about the 300 fourtrax rearends how does the gearing compare? Do they run a sealed rearend?
    Dec 2007
    Quebec,Canada
    1,014
    300 fourtrax is a completly different setup
    1986 ATC500X
    1985 ATC250SX
    1985 ATC200X
    1985 ATC250R
    1986 ATC250R
    1984 ATC250R
    1981 ATC70
    1984 ATC70
    1985 ATC70
    Custom built ATC70 / 250R laydwon swap
    1986 ATC250SX FATCAT
    Central PA
    1,952
    Which one was the same then? 250 fourtrax? Did they use the sx motor too? I did the research on this years ago and I know one of those rear ends works on the atc250sx/es
    PastRides
    SOON MY PRECIOUS!
    Dec 2007
    Quebec,Canada
    1,014
    250sx,250es and trx250 use the same differential(different gearing for the es and trx)
    250es is a unique design for the swingarm
    250sx and trx250 swingarm are very similar,not sure if they interchange
    250es 1985 use a specific design for this year,86-87 is different
    250sx 1985 use a specific design for this year,86-87 is different
    complete rear can be swapped from 85 to 86-87
    no parts will interchange with the trx300
    1986 ATC500X
    1985 ATC250SX
    1985 ATC200X
    1985 ATC250R
    1986 ATC250R
    1984 ATC250R
    1981 ATC70
    1984 ATC70
    1985 ATC70
    Jul 2011
    Greeneville Tn
    116
    Is the gearing on the trx 250 higher or lower than the 250sx
    Dec 2007
    Quebec,Canada
    1,014
    lower
    the SX gearing is faster but i'm pretty sure anybody can feel the difference
    My SX have a 250es gearing and I hit 60 mph.....
    1986 ATC500X
    1985 ATC250SX
    1985 ATC200X
    1985 ATC250R
    1986 ATC250R
    1984 ATC250R
    1981 ATC70
    1984 ATC70
    1985 ATC70
