Page 2 of 2 FirstFirst 1 2
Results 16 to 20 of 20
Thread: 1985 vs 1987 250sx
    Beaver Falls, PA
    2,666
    Quote Originally Posted by atc500x View Post
    250sx and trx250 swingarm are very similar,not sure if they interchange
    pretty sure the trx swinger is longer, someone on here put one on an sx to have a slightly extended swing arm
    Jun 2003
    Anchorage/Homer, Alaska
    480
    The 86/87 TRX swinger is three inches longer than the SX swinger. It will bolt right up to the SX frame with the same bearings, but a solution for connecting the bottom of the rear shock is required.
    The TRX diff has lower gearing than the SX; it turns 25" tires very well. With a 22" tire it has loads of hill climbing power, but the top speed was painfully slow.
    1985 ATC 250ES, Big Red
    1984 ATC 125M's, 1.5 of 'em
    1983 ATC 110, BLUE!
    1974 ATC 70 Pink?
    Jul 2011
    Greeneville Tn
    116
    The sx differential and gears should fit the trx rearend and ai assume you have to you the trx driveshaft as well.
    Feb 2006
    Middletown, Connecticut
    41
    UPDATE: a 87' 250SX rear axle will definitely not fit an 85' 250SX. It's a couple inches longer overal and the splines for the rear right are almost twice as long...
    Will post pictures comparing the two soon....
    ***For sale: 87' 250SX rear axle***
    Aug 2011
    Canada
    I have heard that 85 sx shaft is weaker an can snap when down shifting on a road ? i dont really believe that it will snap but .,i donno
