Results 1 to 15 of 17
Thread: Yt 175
    H95Shooter's Avatar
    H95Shooter is offline At The Back Of The Pack Arm chair racerFirst time rider
    Dec 2010
    north dakota
    174
    Yt 175
    Ok on my yt 175 it wont shift up or down so its stuck in gear could it be I need a shifter fork? Beacuse one person said it was clutch plates then the other said it was the shifter fork. But if it was the clutch plates it would shift right?
    84 atc 110
    82 atc 110
    80 atc 110
    80 atc 185
    70 us 90
    75 atc 90
    84 tri moto 125
    96 xr100r
    96 yamaha warrior 350
    82 tri moto 175
    TTR 230
    ZL 600
    Feb 2006
    EC
    1,607
    Take the right case cover off, it'll give you a god view of how the auto shift works & you might see what's jammed up- the right side is where the sift shaft end is & the clutch also.
    Feb 2006
    EC
    1,607
    So, what's up, did you pull the cover off?
    Aug 2009
    if its an 1983 when u check out the plates DONT LOSE the one spacer plate in the pack u wont be able to find it any where!!!youlll have clutch plates friction plates than 1 spacer do not lose it,clutch wont work right with out it, might be what wrong with it now!
    Wichita, Kansas
    1,359
    If you take out 2-4 balls from the clutches, you can increase the stall before the motor engages. Lets you be closer/in the powerband as soon as you start rolling.
    H95Shooter's Avatar
    Dec 2010
    north dakota
    174
    Im not going to to pull the cover right away. It's more of a sleeper project. But should be running and riding great by winters end.
    84 atc 110
    82 atc 110
    80 atc 110
    80 atc 185
    70 us 90
    75 atc 90
    84 tri moto 125
    96 xr100r
    82 tri moto 175
    TTR 230
    ZL 600
    H95Shooter's Avatar
    Dec 2010
    north dakota
    174
    OK i pulled it was bored killed 30 mins sooo. I will have a video up soon.
    84 atc 110
    82 atc 110
    80 atc 110
    80 atc 185
    70 us 90
    75 atc 90
    84 tri moto 125
    96 xr100r
    82 tri moto 175
    TTR 230
    ZL 600
    H95Shooter's Avatar
    Dec 2010
    north dakota
    174
    84 atc 110
    82 atc 110
    80 atc 110
    80 atc 185
    70 us 90
    75 atc 90
    84 tri moto 125
    96 xr100r
    82 tri moto 175
    TTR 230
    ZL 600
    May 2011
    eden,ny
    3,481
    ha ha I thought I was watching fargo.lol. keep your dremel in the case and download a service manuel. I know a link to your machine was posted in the past day or so. should be pretty easy to find
    H95Shooter's Avatar
    Dec 2010
    north dakota
    174
    DO i have that bad of a accent haha
    84 atc 110
    82 atc 110
    80 atc 110
    80 atc 185
    70 us 90
    75 atc 90
    84 tri moto 125
    96 xr100r
    82 tri moto 175
    TTR 230
    ZL 600
    H95Shooter's Avatar
    Dec 2010
    north dakota
    174
    NOTE it will shift but not out of gear if that maskes sense.
    84 atc 110
    82 atc 110
    80 atc 110
    80 atc 185
    70 us 90
    75 atc 90
    84 tri moto 125
    96 xr100r
    82 tri moto 175
    TTR 230
    ZL 600
    May 2011
    eden,ny
    3,481
    http://www.oscarmayer.net/atc/manual...oto_manual.pdf here is the manuel. yeah you have a pretty strong N. dakotian accent. no offenese I always get a kick out it. it's kinda like a canadian accent with a twist and with out the aye's lol.
    H95Shooter's Avatar
    Dec 2010
    north dakota
    174
    ok thanks but why wont it shift out of gear gears dead?
    84 atc 110
    82 atc 110
    80 atc 110
    80 atc 185
    70 us 90
    75 atc 90
    84 tri moto 125
    96 xr100r
    82 tri moto 175
    TTR 230
    ZL 600
    Mar 2011
    Louisiana
    208
    are you saying it won't shift out of 1st while it is running of while it is not running. If you do not have the engine running it will not shift more than once (sitting still) unless I roll the bike forward some. Then I can get it to shift to the next gear. This is how every atv I have owned is.
    H95Shooter's Avatar
    Dec 2010
    north dakota
    174
    But if its sitting still on my 185 it will sift into N tho.
    Ok if you shift it down it make the click so it should be in N right nope so I shift up it clicks still in 1st. i can tell beacuse when i pull it over the front sproket moves.
    84 atc 110
    82 atc 110
    80 atc 110
    80 atc 185
    70 us 90
    75 atc 90
    84 tri moto 125
    96 xr100r
    82 tri moto 175
    TTR 230
    ZL 600
