My 83 DX is very slowy seeping oil out the left hand side case cover somewhere between the case where the flywheel is and the cover that goes over the output shaft for the driveshaft. Its not much of a leak really no dripping on the garage floor but if you ride it for a few hours you see an oily build up on the side of the case. I have found the gasket that goes behind the flywheel housing but can't find a listing for the gasket on the output shaft cover. There is oil in the output shaft housing right?? Where can I find this gasket for this cover if that is the one leaking? I didnt see it on Yamahas parts site. I just want to fix this without using the dreaded liquid gasket maker![]()
