Results 16 to 30 of 59
Thread: 250SX rear brake upgrade,disc brake!!!!
    ontario
    1,131
    For now my SX is on 9 inch ES wheel,I will check but I'm pretty sure the 200x wheel will fit
    Thanks for the comment,I will complete the setup tomorrow and test it.
    the 200x rim will probably fit with your disk brakes now. I tryed my 200x rim on mine today didn't fit around the brake drum. lol
    1984 110 project
    1984 125 parts bike
    1983 honda 200x
    19 85x2honda 200x
    1985 honda 250sx
    1985 honda 250es
    Oct 2007
    Minneapolis mn
    4,067
    ^^ 400ex 9" wheels will not fit over the drum either, without a spacer (fwiw)
    Dec 2007
    Quebec,Canada
    1,014
    Quote Originally Posted by hillbilly 200x View Post
    83-85 200x wheel will not fit,bolt pattern is correct,but the diameter of inside the rim doesn't clear the diameter of the SX hub.I have 4 1/4 of offset clearance
    1986 ATC500X
    1985 ATC250SX
    1985 ATC200X
    1985 ATC250R
    1986 ATC250R
    1984 ATC250R
    1981 ATC70
    1984 ATC70
    1985 ATC70
    Custom built ATC70 / 250R laydwon swap
    1986 ATC250SX FATCAT
    Dec 2007
    Quebec,Canada
    1,014
    It work!!! Some picture of it.The SX wheel and the ES wheel fit perfect.Since I removed the park brake system I will remove the handle and cable,and install a XR decompressor lever just for the reverse system
    1986 ATC500X
    1985 ATC250SX
    1985 ATC200X
    1985 ATC250R
    1986 ATC250R
    1984 ATC250R
    1981 ATC70
    1984 ATC70
    1985 ATC70
    Oct 2007
    Minneapolis mn
    4,067
    SO SICK!! I love it!
    East Central Illinois
    677
    Very Awesome. I'm still a little fuzzy on the details of the swap, but I think if I looked at the 250sx I'd be fully capable of replicating this sweet innovation. Thanks for sharing your work.
    nstyle73
    "When in doubt, wind it out"
    Feedback: http://www.3wheelerworld.com/showthr...k-for-nstyle73
    Dec 2007
    Quebec,Canada
    1,014
    Just back from first test,unbelievable,best brake I ever seen on a SX,3/4 inch play to the pedal and the wheel lock so easily....
    The XR decomp lever used for the reverse is a direct fit,the cable fit right in the handle,no cable adjustement needed.No more problem with cable!!!!!
    This week I will built the front!
    1986 ATC500X
    1985 ATC250SX
    1985 ATC200X
    1985 ATC250R
    1986 ATC250R
    1984 ATC250R
    1981 ATC70
    1984 ATC70
    1985 ATC70
    Beaver Falls, PA
    2,666
    Fantastic idea! I hate the way the reverse setup is on the SX/BR... I may just do the decomp lever mod by itself!
    Sarnia, Ontario, Canada
    3,415
    'ATC500x', love the work you've done..1st rate. But I'll think I leave my 250SX with it's stock drums..it's my heavy mud machine.
    You should consider makeing conversion kits for some of these creative ideas you have. I know there are buyers for your stuff here!!
    Current toys..
    1986 Honda 350X..trail bomb!
    Current non-trike toys:
    1990 Honda TRX300FW
    1995 Seadoo GTX
    1998 Polaris Touring 500
    1998 Club Car (electric)
    So have you got to ride it much more to see how it will hold up ??? it looks like there would be alot of leaverage on the disk adapter. I wounder if there would be alot of differance in the stoping power if it were a single piston caliper ??? I would like to keep my parking brake
    Dec 2007
    Quebec,Canada
    1,014
    I have ride it a lot,normal riding and deep mud.Always perfect,powerfull in any condition.I have also fit a front disc brake too.
    I'm pretty sure a single piston caliper will do the job,but for the difference of work,I would stay with the dual piston,but using a newer atv rear caliper with the park brake system is a good option if you want to keep the park brake.I have use the parts available in stock.
    1986 ATC500X
    1985 ATC250SX
    1985 ATC200X
    1985 ATC250R
    1986 ATC250R
    1984 ATC250R
    1981 ATC70
    1984 ATC70
    1985 ATC70
    Do you have a better pic of the adapter I would like to really do this to our big reds
    Oct 2007
    Minneapolis mn
    4,067
    Thinking of building a kit? I have a ES and a SX patiently waiting....
    Nov 2010
    Oshawa, On, Canada
    2,123
    I would buy these kits!!!!!!!!
    1985 Honda 250r x2
    1986 Honda 250r
    1986 Honda 250sx
    1985 Honda 250sx x2
    1985 Honda 350x x2
    1986 Honda 350x
    1984 Honda 125m x4
    1984 Honda atc 70
    Yamaha tri zinger
    Yamaha 4 zinger
    Brap braaaap
  15. #30
    Dec 2007
    Quebec,Canada
    1,014
    I don't know If I will built a kit and sell it.I kept all the pattern of parts I built.But for the moment,I just don't have time to do anything.Just find time to sleep is a job....to much work,too much idea!!!!!!
    1986 ATC500X
    1985 ATC250SX
    1985 ATC200X
    1985 ATC250R
    1986 ATC250R
    1984 ATC250R
    1981 ATC70
    1984 ATC70
    1985 ATC70
