Could you post up some pics of your front disc setup?
1974 Honda ATC 70
1985 Honda ATC 250 ES Big Red
1986 Honda ATC 250 ES Big Red
2008 Honda Rancher 420
1983 Hustler 945-HK 6x6 - Fire Breathing 627cc V-Twin Monster
2010 Chevy Silverado 1500 4x4 LT
1983 GMC K10 Sierra Classic Suburban 6.2 Liter Diesel
My Feedback:http://www.3wheelerworld.com/showthr...-for-Stonewall
There is no Z in Diesel!!!
Yes I will took some picture of the front setup
Don't forget you need an old backing plate that need some work on the milling to fit the bearing and cler the disc.
With my experience in this built,if you don't have access to a machine shop with a lathe and milling,to built good parts,the cost of labor will be very high.
Locally the cost of used parts are expensive.But it's approx the same as ordering a part on ebay + shipping
My hub with the disc cost me 75$ locally,the price was 45 on ebay + shipping,approx 25$.
Will check for more picture and will post.
1986 ATC500X
1985 ATC250SX
1985 ATC200X
1985 ATC250R
1986 ATC250R
1984 ATC250R
1981 ATC70
1984 ATC70
1985 ATC70
Custom built ATC70 / 250R laydwon swap
1986 ATC250SX FATCAT
Looks like you have some customers in line already. LoL.
Nice work.
Last night I put new wheels on my BR and had the opportunity to snap a few pics of my rear disc brake set-up.
The first pic shows the wielded tube (the ID of the tube is slightly great than the OD of the axle housing). It is about 3" long.
First we wielded the tube to the hub and then wielded the disc to the tube as straight as possible. You can also see we made custom brackets to mount the caliper to the axle housing using angle iron and a lot of grinding, :-)
Here is the bracket for the caliper on the front side of the axle housing.
Another shot of the tube, disc and caliper.
My wheelers:
current:
'86 Honda ATC Big Red 250es - disc brakes, lifted, spaced and 27" Super Swamper TSL / Vampire (1.22" lugs) all-around
'86 Honda ATC 250sx - Mud Bugs (1.19" lugs) in the rear
'85 Honda ATC 250sx - not currently running
'85 Honda ATC Big Red 250es - runs
previous:
'85 Honda ATC 200s
Ok I'm digging this old thread up. Me and my brother and kizer and big daddy tri-z where out riding big reds sunday and we were playing in the mud and none of bikes brakes worked very good after that so we need to dig this thread back up and get this figured out. Ok I was thinking for the people the like to use there hand rear brake and foot brake, do they make a brake system that can have two masters hooked to one caliper?? Like have the hand brake master cylinder line piggy backed on top of the foot brake master line??? And is there any calipers that work better than others ????
This is a good conversion.But I like the drum brake on my 250r.Id like to figure out how to make it a hydraulic drum setup. Iv checked some brake systems on a couple utility quads it look posible. I read an article in Dirt Wheels years ago where the guys put disc brakes on a trx 2 wheeldrive.They used all oem honda parts.
250r rules
I'm pretty sure there's a rear disc brake conversion kit for the TRX300 util quad available,which would work on the ES or SX but it's really expensive................
Ok do you have a link to the REAR disc brake conversion?? I've been all over the web and can find it all I can find is the front kit
pretty sure they exist only for the front.The front are expensive,I'm doing a front kit setup on my trx300 now with a trx250r setup,easy to do....
1986 ATC500X
1985 ATC250SX
1985 ATC200X
1985 ATC250R
1986 ATC250R
1984 ATC250R
1981 ATC70
1984 ATC70
1985 ATC70
ever get any pics of the front setup??
current rides
82' ATC110
85' ATC310R
85' ATC250R
85' ATC250ES
16' brute force 750
I didn't read all this but front is cake if you simply slide in 200X forks.
You can use SX forks with a creative bracket though....
It's exaclty what I did,250sx stock clam and 200x shock
1986 ATC500X
1985 ATC250SX
1985 ATC200X
1985 ATC250R
1986 ATC250R
1984 ATC250R
1981 ATC70
1984 ATC70
1985 ATC70
