Results 1 to 15 of 19
Thread: Carb advice needed!!!
    Hey guys, just picked up an old 185 suzuki trike, it needs a new carb....my question is will a carb off of a honda 200 or something like that, with the same millimeter measurements fit on the suzuki..... I believe that the suz. 's measurements are 22mm and so is the honda 200m,(forget what year) -- any help would be great guys, thanks!!!
    Come on guys, any help would be great, thanks!
    VABCH350X is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Aug 2003
    Whidbey Island, WA
    322
    Why does it need a new carburetor? There's not much that can go bad on those, and rebuild kits are readily available. I'd stick with the stocker man.
    86 Honda ATC350X
    86 Honda TRX70
    02 Honda TRX400EX
    03 Kawasaki KFX80
    82 Honda CB900F
    Rittman, Ohio
    6,276
    Quote Originally Posted by VABCH350X
    I would agree. Do you have the stock carb?
    Im afraid there probably not much specific hands on advice for your 185, as they are pretty rare.
    well im not very familiar with carbs as it is, the carb is still on there, i just picked the machine up the other day and havent had time to pull the carb out yet, but the guy i got it from said " it needs a new carb and its carroded around the main jet" thats about all i know!
    May 2002
    Dublin, Georgia
    635
    I have clean and rebuilt a couple like that one.
    Unless you have tried to rebuild it I would try that first. A new carb is kind of spendy. (~$150). I would completely dissassemble the carb, sok the metal parts in carb cleaner overnight. Then clean them with an old tooth brush. Get a carb kit and replace all the jets and seals. It is a pretty easy process.
    84 ATC200X--Wife rode it once, now I can't get it back.
    84 ATC250R--Trying to find piston for 300R kit.
    85 ATC350X--Project finally under way, slow progress. For pics: http://groups.msn.com/ATCfriends/350xproject.msnw
    84 ATC200S--Freebie from a neighbor, needs topend rebuild and tires.
    Rittman, Ohio
    6,276
    Yep, just take it apart and clean it, take all the jets out and clean them as well, using Gumout, or some other spray carb cleaner. Be sure you can blow cleaner or compressed air through every orifice. You may get mineral deposits or varnish, but carbs do not "corrode".
    Aug 2003
    Whidbey Island, WA
    322
    If you intend to re-use the rubber o-rings and gaskets make sure you don't let them soak in the carb cleaner, it will make them expand and deteriorate.
    86 Honda ATC350X
    86 Honda TRX70
    02 Honda TRX400EX
    03 Kawasaki KFX80
    82 Honda CB900F
    Thanks alot guys, im gonna have it soaking over night, i took it apart and it was sooooooooo dirty, brown gunk all through it!
    had it all cleaned out perfect, put it back and and sitll no luck, any ideas guys why she wont start, i know its a general question but any help is great!!!
    May 2002
    Dublin, Georgia
    635
    Fuel in the carb
    Are you sure fuel is getting to the carb? Do you have spark? These are your first two questions.
    ok i know fuel is definately gettin to the carb, just took the spark plug out, got an easy test to see if she's still good????
    Eastern Long Island
    1,688
    Give the spark plug the float test. Go to any body of water and throw the plug in. If it floats it is good. :-D . Seriously, if there is any ? about the plug just buy a nw one. I have seen lots of plugs that would spark when held against the motor but not make it run.
    Lots O Trikes!!!!!
    Quote Originally Posted by quadfreakshow
    You DID unscrew all the jets right?? I was paranoid my whole life about "jet" removal until some of these guys smacked me around a couple years back. A clean fuel bowl means nothing, you have to get all those fuel passages spotless.
    Yes i did!lol i had er in pieces,
