Results 1 to 8 of 8
Thread: Removing Baked On Decal Adhesive?
    Escanaba, MI
    15
    Just wondering if anyone has anything from their bag of tricks that will work to remove decal adhesive from a plastic? I'm giving a one over to my 86 225dr and tried all the usual stuff (goo gone ect) with almost zero luck. Machine has spend a good amount of time sitting out in the sun with only the decal adhesive left to bake on....
    Dec 2010
    Back in VA baby!!
    711
    mineral spirits, wd-40, try using a hair dryer to soften up the adhesive....
    Oct 2007
    Minneapolis mn
    4,067
    Laquer thinner
    Jun 2009
    Tunkhannock,Pa
    904
    Goof Off works well
    1985 200X
    66mm H&S Piston
    Little Bit Bigger Cam
    Bassani Exhaust
    1985 350X With Bassani Exhaust
    1983 Honda 200E (PARTING OUT!!!!)
    1985 Yamaha Tri-Zinger
    My Feedback Threadhttp://http://www.3wheelerworld.com/showthread.php?105185-Feedback-for-RodKnockRacing&highlight=RodKnockRacing
    JustEnough's Avatar
    JustEnough is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Oct 2009
    Elk Grove, CA
    334
    I have heard brake fluid is good for removing paint from tanks and Clarke says that it is safe for their tanks.
    Feb 2008
    (southern) Wisconsin, USA
    974
    Acetone will dilute that goo like a few of the previously mentioned chemicals , but WAY better. First try to rub the old adhesive into a ball without any chemical. It should clump to itself and make a tiny ball (sometimes if malleable). If not, thin out the old hard adhesive a bit with acetone and try again to rub it into a ball. If you dilute it too much, It'll just smear all over and require a lot more work (wiping)
    Acetone is kinda harsh, but shouldn't hurt plastic at all. I don't recommend use on painted surfaces. Maybe wear some gloves and breath deep....(LOL) Ahhh, nice and fresh! Kidding~ VERY FLAMMABLE
    Good luck!
    mirthgrinder is offline At The Back Of The Pack Arm chair racerFirst time rider
    Cypress, Texas, United States
    180
    WD-40, I buy it by the gallon at the hardware store...
    MG
    200 is offline First Time Rider Arm chair racerNew to the board
    Jun 2011
    I use paint thinner and it works well.
