If he was smart, he would do it when she isnt home then claim ignorance when the chicken tastes like oil. This is why I have a wall oven in my garage. An alternative is to buy a small countertop oven for less than 50 bucks.
I have tried applying MAPP gas heat and it didn't have the same effect. Heating the entire part in the oven workes very well. I now use this method for installing most bearings. SX axle tube, front wheel hub, tranny, crank, rear carrier etc..... Most bearings stay in place with whats called an interferrance fit meaning the bearing is a CH larger than the hole. Heating the part expands the bearing hole and freezing the bearing shrinks the bearing and in most cases allows the bearing to drop in to the hole with little or no effort. All you have to do is wait till the part cools off. I was putting bearings in to a 250R case and I dropped the bearings in and flipped the case over and all the bearings fell out. This is also a great way to install timing chain gear on the crank for the 185/200 series motors.
well the bearing is in the freezer for the night. we finally got the needle bearing out after 4 nights of working with it. we ended up fracturing the case in the process. im so fed up with the rebuild i dont even care anymore so it will be getting jbweld tomorrow and everything reinstalled. i also plan on NEVER rebuilding another one....this has been over two weeks of hell
current rides
82' ATC110
85' ATC310R
85' ATC250R
85' ATC250ES
16' brute force 750
Do you need a case?
You want me to put it together with a fresh case? Send me your diff and the rebuild kit and I will return it looking like new.
ill tell you the truth between buying all my esr parts for the 250r, christmas and the bearing kit for this diff..i am about out of extra money...just curious how much would you charge for a new case if i cant fix mine
current rides
82' ATC110
85' ATC310R
85' ATC250R
85' ATC250ES
16' brute force 750
It's not about money for me. I have an extra case I'm offering up along with my services. Just cover shipping and I will take of the rest. It's Christmas time..... What can I say.
i dont think im going to have any problem putting it back together...and thank you so much for offering to put it together...but i will certainly pay shipping on the case to 23661 if you dont mind sending it...any parts you need? maybe i can send you something
current rides
82' ATC110
85' ATC310R
85' ATC250R
85' ATC250ES
16' brute force 750
Not a problem. PM me your address. I'll send it USPS flat rate so 11.20 for shipping. I'll put my return address in the box. Would you like the case powder coated? Right now its completely stripped (bead blasted). I PC my own stuff.
What a gentleman you are Flyingw! Thats a real man right there.
Isn't that why we come here. To help eachother out.
