Results 1 to 2 of 2
Thread: extra credit poem. H.S. english class. They got an 'A'.
    Pacific NW
    4,255
    Engine --
    Look at you, drinking gasoline
    in a steady flow,
    Purring with the easy shake of the
    exhaust,
    Turning the fan and circulating water
    to cool yourself
    Easy as can be ...
    We use, but rarely admire you,
    Your faithfulness, your loyalty,
    your rhythm,
    Nimble as a dancer's step ...
    All know the greasy metal,
    the stink, the heat, the cracked
    and grimy gaskets, the defeated clutch,
    the shoeless brakes that have eaten
    into their drums, exploded mufflers,
    failed tires, dead batteries,
    While so few have appreciated with
    understanding
    the steady beat of all the engineering
    ticking fine --
    It's a miracle, and a homey one at that:
    So many things working together to turn
    a single shaft.
    Valves opening and closing to the
    predetermined rhythm
    of the ever-turning crank,
    Communicated through the simple mechanism
    of a chain.
    Oh spark-plugs, sparking at the command
    of the
    loquacious rotor
    Oh silent coil secretly amplifying
    the power of the battery
    Oh carburetor, mixing air and gasoline
    like an alchemist
    Oh oil-pan humbly lying below all things,
    filling up with sludge and filings --
    Oh engine, we take for granted the burden
    you bear --
    mutely your cylinders and rings wear away --
    your flywheel loses its teeth --
    your valves become encrusted --
    the intelligence of your steel decays,
    is worn away by time -- you fumble,
    you falter -- the trim muscles of good
    compression waste away -- gravity gets you
    down -- you do not make the hills, you
    cannot
    pull the load anymore.
    Oh worn away, oh broken down,
    Oh tired and unsteady, you are
    passed on to the poor,
    To those who gamble on a transmission
    And play Russian Roulette
    with a recalcitrant starter.
    And you will try, you will exert yourself
    To uphold their faith,
    Drinking watered gasoline, putting up with
    Quantities of cheap oil that you
    Blow out in a sickly exhaust.
    So come away, come away then
    There is no heaven for you, to be
    earned
    By grace or works !
    Render them good service --
    Three-hundred dollars worth and then,
    in the parking lot of the supermarket,
    in the carport,
    on a long haul over a steep hill,
    Give it up --
    Burn your bearings,
    crack your head,
    throw a rod,
    Give it up ! Disintegrate the order
    that maintains you,
    forget the intelligence that makes you
    different from scrap,
    Annihilate the hot homeostasis that
    maintains your monotonous life --
    Give it up, like a fevered
    illusion,
    And submit to the junkman's hook.
    1,736
    Pretty awesome
