Results 1 to 15 of 22
Thread: How to make a 200x faster
    Aug 2011
    michigan
    17
    I just bough a very nice 200x very good condition but this thing is slow. I have never rode one were they all slow like this i would sya this thing will only do 40mph is there anything i can do or is this machine always going to be slow also they feel like they need a sixth gear it feels like it has more motor just runs out of gears
    Baltimore, MD
    6,088
    Well, it sounds like you just answered your own question. Change the gearing. Of course the tires have something to do with gearing as well. If you change one of your sprockets and soon change your rear tires, then it may very well mean you will have to change your gearing again.
    Nicholson 500x (Project)
    Nicholson 185s
    PK Racing Suspension 70
    A+ Inc Suspension 70
    AWS Aluminum 90 frame
    Beaver Falls, PA
    2,666
    X2^
    Also, what size rear tires are on it? 22" is stock, but some people put on 20" or even 18". That'll gain you power but drastically reduce top speed.
    Buy a 350X.
    Crest California
    3,014
    Stroke it, bore it, run on alcohol, run an XR200 6 speed tranny and run a turbo with an accelerator pump carb. That'll boost the power.
    LED obsessed
    2015 Yamaha FJ-09
    Terryville,CT
    1,616
    or a fresh top end and gearing will do plenty
    2- 85 250SX's
    1- 85 200X
    3-ATC 70's
    ontario
    1,131
    Buy a 350X.
    best answer so far
    1984 110 project
    1984 125 parts bike
    1983 honda 200x
    19 85x2honda 200x
    1985 honda 250sx
    1985 honda 250es
    pcs's Avatar
    pcs is offline Just Too Addicted Arm chair racerJust too addicted
    Jan 2011
    yuma, az
    465
    i ran a gps on my friends 1983 200x, original motor, no muffler (fell off), 20" rear wheels and i could hit about 48mph on the dirt, might be something wrong with your engine.
    my 200x has a fresh top end, look at sig, and its still slow, i havent used the gps yet bc i busted my pulse generator but i could pace my truck and my car on the asphalt around 53mph with stock gearing and a 22" rear tire. i know that car speedometers are always off but i know its much faster than my friends stock 200x
    Team Blue: 85 Tri-z 250: under the knife
    Team Red: 87 Trx250r 01Cr80 15 CBR600RR
    Team Yellow: 06 Ltr450 11 Hayabusa
    Glad to hear no one says their 200X does 60 MPH for once!!
    Crest California
    3,014
    Not impossible, but of course it wouldn't be a stock bike, not by a long shot...
    LED obsessed
    2015 Yamaha FJ-09
    Aug 2011
    michigan
    17
    my trike has 18 inch tires maybe that is the problem how would i change the gearing or should i just change a sprocket which one do i go bigger or smaler
    Phoenix, AZ.
    6,719
    14/37 gearing works awesome with 18 inch tires (assuming the motor is strong). Mine had mostly just bolt on mods and with that size tire and gearing it moved along just fine.
    louisiana
    1,499
    never rode with a gps on my 200x's,but i know last time i checked the speed with a gps on my ytm 225,it toped out right at 54
    Signature pic removed,becuase of no helmet.
    Northern, California US
    105
    Mine does 60, but it does have a stroker.
    Apr 2008
    Metro Detroit-MICH
    244
    Quote Originally Posted by Dammit! View Post
    14/37 gearing works awesome with 18 inch tires fine.
    What is stock gearing?
    Trying to decide what sized tires to go with because I need some new ones.
    Alex Stoli
    1986 Honda 250SX-X
    1985 Honda 200X
    1984 Honda ATC 70 w/ piranha 90
    1983 Honda ATC 70 w/ Pitster Pro E110
    TRIKEFEST 2011 vet
    SandPupi's 2011 vet
    Member #13036
