Results 1 to 7 of 7
Thread: 108 big bore for ATC90
    Aug 2011
    Sioux Falls
    4
    I have a '78 ish atc 90 that I would like to bore out to 108cc. The kit that i found includes the piston, wrist pin and rings. Is there any thing else that I need? Rod? Head? Or anything else?
    Ripley Tn
    1,363
    just a top end gasket kit and sounds like your set
    85 Atc 70
    86 Atc 125m
    85 atc 350x
    86 atc 250r
    86 Atc 250r TT build
    85 Big Red bought brand NEW
    2012 Honda Goldwing Gl1800
    Aug 2011
    Sioux Falls
    4
    Thankx and wat do I have to bore the cylinder to?
    Ripley Tn
    1,363
    take it to the machine shop and they will measure the piston and bore from there
    85 Atc 70
    86 Atc 125m
    85 atc 350x
    86 atc 250r
    swifty's Avatar
    swifty is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    sabula iowa
    381
    if your not adding a bigger carb cam and aftermarket exhaust the big bore will make almost no diffrence alone
    ACT NOW THINK LATER!
    current trikes owned
    minty 86 250sx my rider
    pauter flat track framed 110-123cc with custom goodies
    pauter mx framed 110-123cc with aftermarket goodies
    joker framed 90-108cc with front suspension
    2007 artic cat DVX 400
    dickson sprint framed 73 green us90 with 110 engine
    Aug 2011
    Sioux Falls
    4
    110 carb? What would you suggest for carb, cam, and exhaust
    Crest California
    3,014
    I have heard good things about Mikuni VM carbs. Might want to try a VM22, and then an exhaust like a Supertrapp or something.
    LED obsessed
    2015 Yamaha FJ-09
