Results 1 to 12 of 12
Thread: The New to Me US90 is Here.....mmmm?
    Cold Lake, Alberta, Canada
    3,019
    Well it survived the 2000 mile bus trip with just a bent plate behind the sprocket. All I can say is this is the last trike I buy sight unseen. Don't get me wrong, it seems lightly used and is fairly complete but the seller may have left out a few details, like;
    1. The tires are fair at best. No plugs or patches but some dry rotting
    2. There is no spark even though he said it run a year ago when he sprayed gas in the carb. Any ideas why it would lose spark without running over a year? I cleaned the rust off the rotor, changed the plug and disconnected the kill switch? Still nothing.
    3. There is paint splatter all over the pristine seat and rear fender. Any idea how to get it off?
    4. It is missing the gas tank pad and strap.
    5. The light switch pig tail has one wire broken off.
    Check out the pics after I put it back together and cleaned it up. Any ideas on above questions welcome. Thanks!
    Attached Thumbnails Attached Thumbnails 005.jpg   002.jpg   003.jpg   001.jpg   004.jpg
    Trikes
    1970/71 US 90 (Aquarius Blue)
    1972/73 US 90 Green
    1982 ATC 70
    1983 ATC 70 (Ladybug)
    1973 ATC 70
    TF 2015
    Other
    1983 Honda Z50
    N.E. Ohio
    2,005
    Try steam cleaning it... my steam shark has come in handy for over spray and exactly what your mentioning(not high pressure just a household cleaning machine). Look to these guys for your part needs...just may have what your looking for www.hondanuts.com
    May 2011
    eden,ny
    3,481
    castle brand "brake bath" will take over spray right off. I have used it on plastic and painted surfaces without a problem but I go right behind it with soapy water and then a rinse to be safe
    Beaver Falls, PA
    2,666
    Mighty Green... sweet! What's up with the grab bar and tail light? Looks cool, but nothing like mine...
    NEPA
    7,051
    Points need filed. That'll give ya spark. All great ideas above for the overspray. I find different things work better on diferent paints. Just when I think I've got it figured out,,along comes some I can't get off! I usually use gas,or paint remover,,,followed VERY quickly with nice sudsy water. You don't want ANY of these hanging out on a 40 yo seat any longer than neccessary! Nice trike. Enjoy!!
    6,808
    X2 on filing the points and if that doesnt do it replace them , even if they look good they do go bad over time .
    ontario
    1,131
    X3 on filing, but you have to clean them after words take a 5dollar bill and spary it with carb cleaner, turn the fly wheel so that the points are open, put the bill in the opening then turn the fly wheel until the point close then pull the bill out. you may want to do this a few times
    1984 110 project
    1984 125 parts bike
    1983 honda 200x
    19 85x2honda 200x
    1985 honda 250sx
    1985 honda 250es
    May 2011
    eden,ny
    3,481
    Quote Originally Posted by hillbilly 200x View Post
    I was going to ask why use a 5.00 bill then I remembered you are in canada I guess a loony wouldnt have the same affect lol.
    3,019
    All great ideas guys. I'm off to a show'n'shine with both US90's today but I'll try those tricks when I get home.
    Trikes
    1972/73 US 90 Green
    1982 ATC 70
    1973 ATC 70
    TF 2015
    Other
    1983 Honda Z50
    Oct 2007
    Minneapolis mn
    4,067
    My us90 was running one minute, and not the next... Had to clean up the grounds for the coil.... Popped off first pull after that...
    glendive, montana
    1,822
    also have you check the kill switch itself yet 2000 mile trip wires could have rattled loose in there, also is it just me or are the handlebars bent a little
    3,019
    Great idea on the points, ATC007, Shortline10 and Hillbilly200X. I got her to run after I did that trick. Thorpe, I did clean up the coil grounds ealier and I disconnected the kill switch all togther to eliminate that possibility Muthey. Now for the carb issues.
    Thanks again folks!
    Trikes
    1972/73 US 90 Green
    1982 ATC 70
    1973 ATC 70
    TF 2015
    Other
    1983 Honda Z50
