i got a 85 honda 200x it won't idle right it idles high and if i shake bike the idle drops when riding it sticks at high idle until i goose it then drops it will stall when riding i also noicted gas leaking out of the overflow tube any ideas thanx
Bad float springs(leaking), intake leak from the carb to the motor causing stall while stabbing the gas.
Check float....
1978 ATC70 w/ Piranha 140cc
2017 YZ 250x- Braap
Check the O-Ring on the intake manifold where it goes onto the engine. If that is bad it'll cause a lean condition. Always good to check em each time you take the carb off.
