Results 1 to 2 of 2
Thread: 83/84r swing arm sprocket hub
    nik0708 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Aberdeenshire, Scotland. U.K
    417
    Hi guys,
    Can any of you tell me if the rear aluminium sprocket hub can be removed from the axle? I thought if you pressed out the four rubber mounts then warmed the aluminium slightly, the hub might press off the axle in the direction of the bearing carrier?
    I need to have the axle re-plated and obviously can't do this with the ally hub fitted.
    Cheers,
    Nick
    417
    Answered my own question tonight, the sprocket hub does come off the axle, it just took around 10 Te of force in the press and some heat.
    Nick.
