Results 1 to 15 of 17
Thread: Need a suggestion on broken exhaust bolt. 350x
    Aug 2011
    texas
    22
    Hello again yall. I took apart my exhaust about 2 weeks ago to repaint it. The 350x has 2 header pipes that come out of the engine with 4 bolts.
    Long story short, I broke off the last bolt. Im in the process of getting that bolt out.
    My question is, is that im trying to find a replacement bolt. I have searched bike bandit and service honda and that bolt is not on there. Any body know where I can get one or what I can do?
    Pacific NW
    4,255
    try the search key on here for broken bolt and generally
    dirtcrasher has THE best info so he may be pretty busy these days.
    I've hear of using stainless steel bolts, and studs but best to get the real answers
    before you make it worse, which is what I'd probably do.
    canada
    74
    use heat to extract it iF THERE IS ENOUGH to get a hold of..
    Aug 2011
    texas
    22
    thank you guys I acctually found the part on service honda. It is was not on the exhaust parts, had to type in the part number. But yeah I tried vice grips today, I have been spraying lube on it everyday for the past 7 days. Im talking to a mechanic at my job tomorrow.
    canada
    74
    use heat a torch IF YOU HAVE A STUB LEFT TO GRIP..
    Pacific NW
    4,255
    left handed drill bits MAY bite it while drilling and twist it out if it's not bottomed out tight.
    but remember that ez outs and drill bits are hardened steel and they DO snap off and are impossible to drill out
    and then something about stainless bolts or studs and antisieze compound.
    Yupp
    I walk around all my trikes with pb or liq wrench and hit the exh studs and front axle bolts at least once a month
    in preparation for that special day that is sure to come.
    Quote Originally Posted by viking View Post
    Is there an echo in here?
    He's not asking how to get the old one out. He's asking where to get the new part. Believe it or not, many of us on here have been doing this stuff for a long time. You're making yourself look silly by stating the obvious.
    I am fairly certain DC uses stainless steel. You may want to give that a shot instead of putting the regular steel studs back in. I'm sure the stainless ones come out a lot easier down the road. I know DC uses McMaster Carr a lot. That may be where he gets his studs.
    canada
    74
    HE WOULD HAVE not had the problem if he would have
    USED HEAT
    canada
    74
    I think you maybe YOU MIGHTY BE A bit of QUEER there fabio???...
    anyonE whom calls him self fabio and is proud of it is well sorta FRUIty IN MY BOOKS
    IS THIS NOT CORRECT?
    ?mAYBE YOU SHOULD STICK TO BAKING cookies and barbies? ???
    ha AND DONT TAKE IT TO HEART BUD IM JUST RIBBING YA LOL
    canada
    74
    Echo that a few times fabio..
    Dec 2009
    BFE
    1,202
    Wow thats a good way to get banned on this site calling members names and trying to start problems. Better just cool off for awhile dude.
    "I'm Kind Of Like The Turtle Man Of 3Wheelers."
    1986 Honda 350X
    1985 Honda 250R
    1985 Honda 200X
    canada
    74
    HEy thanks SWAMP but all i was doing was trying to help this other dude out and others by
    SAYING when dealing with exhaust or any stuck or rusty impossible bolt USE HEAT
    you will hardly ever break a bolt or exhaust stud that way,,
    ITS CALLED PREVENTED MEASURES FOR NEXT TIME
    READ IT AND WEEP SO YA AGAIN
    USE HEAT!!
    My god, name calling? Really man. Keep it up. Watch the ban fall.
    Just when we finally got rid of bcredneck too...
    Nov 2010
    Oshawa, On, Canada
    2,123
    When will people learn.....
    To OP. x2 What Fabio says.. I also suggest going with stainless steel. I drilled both of mine out, and installed ss studs, and they are great. You can buy them from a Honda Dealer.
    Jason
    1985 Honda 250r x2
    1986 Honda 250r
    1986 Honda 250sx
    1985 Honda 250sx x2
    1985 Honda 350x x2
    1986 Honda 350x
    1984 Honda 125m x4
    1984 Honda atc 70
    Yamaha tri zinger
    Yamaha 4 zinger
    Brap braaaap
    Mar 2007
    Texas
    5,045
    Viking,
    Do the world a favor will ya? Pull your bottom lip over your head and SWALLOW.......
    ________________
    https://www.mikesatvfix.com
