Results 1 to 9 of 9
Thread: Terribal day!!
    Jun 2009
    Tunkhannock,Pa
    904
    Terribal day!!
    Well there's a lot of flooding in Northeast Pa from all this rain. Today I went out to my shed to see if I got any water in there well I did, and I took my 200x engine apart the other day so I can put a new kicker spring in when i get it. But now all my parts are soak and wet the only thing that didn't get wet was my BAPP Piston. Now I think I'm just gonna find a different engine and try to dry out the rest of my parts. Sorry I just had vent.
    1985 200X
    66mm H&S Piston
    Little Bit Bigger Cam
    Bassani Exhaust
    1985 350X With Bassani Exhaust
    1983 Honda 200E (PARTING OUT!!!!)
    1985 Yamaha Tri-Zinger
    My Feedback Threadhttp://http://www.3wheelerworld.com/showthread.php?105185-Feedback-for-RodKnockRacing&highlight=RodKnockRacing
    Springfield Mo
    3,309
    Dry the parts the best you can, then blast them with a silicone spray. You should be fine as well if you hit them with WD40 or oil.
    RIP Ninja!
    Trike Fest 2011, 2012 Vet!
    Trikes Currently Owned:
    87 Big Red 250es
    83 Honda 200s
    81 Honda Atc 70
    (4) Suzuki ALT 50's
    Yamaha YT 60
    Yeah man, the water isn't going to kill them. Just dry em off and put some oil on em.
    Pacific NW
    4,255
    Did I hear that the wd in wd40 stands for
    water displacement?
    I'll hafta re read the label but I think it says it will displace water
    on things, like electrical and obviously metal parts.
    Also hear on a thread here that it's not necessarily good to sprat
    gas tanks with because it dries out and allows moisture back into the rust after a (long) while?
    That shouldn't be an issue for you and yer parts tho.
    Have I seen gallons of it too?
    If it's cheap enough, maybe a dip of each part into it
    and then pile them into the infamous 5 gal bucks to drain onto each other.
    I had a few gas tanks that I drained beautifully and left in the 90 degree sun for a few days.
    yupp, you guessed it, it rained for a bit and they all got watersoaked so I get to start over.
    You still got food and good water?
    They say most wells are sealed from surface water contamination.
    No sense in having a situation go from bad to worse.
    On a lighter note, I wonder what they did with "wd" one thru 39?
    Springfield Mo
    3,309
    You are right Doc. WD= Water Displacement. 40= the number of different formulas used to reach the desired product.
    RIP Ninja!
    87 Big Red 250es
    83 Honda 200s
    81 Honda Atc 70
    (4) Suzuki ALT 50's
    Yamaha YT 60
    Jun 2009
    Tunkhannock,Pa
    904
    Thanks Guys
    I have food and water drjoe
    1985 200X
    66mm H&S Piston
    Bassani Exhaust
    Lauderdale County, Alabama
    2,029
    Here's what I do with wet parts. Dry em the best you can, spray em down with PB Blaster, pour out the excess, then coat em with WD or spray RemOil lightly on them.
    Aug 2011
    Stewartstown, PA
    73
    Hey man were in the same boat as you down here in south eastern PA. This weather has sucked this whole week so far but like dr.joe said our water is cut till they get ahold of the contamination problem. And wd-40 does work wonders i think my old man uses it on everything.
    Apr 2010
    Surrey, ND
    82
    I've heard most people have had pretty good luck getting just about anything with an engine (besides cars) being brought back to life again after being completely submerged under 8-12 feet of floodwater and all the muck that comes with it as long as you drain the fluids and clean the carb you have a good chance of getting it going again. Over 4000 people up here in the Minot ND area suffered severe flood damage to their homes and businesses back in June and are still trying to recover and get things back to normal as much as possible before the snow flies again. Good luck with your project and I really feel your pain with the flooding since I know many people who lost their houses. Most did not have flood insurance either & FEMA is broke too, leaving many walking away from their mortgages...
    1985 Honda ATC70
    1983 Honda ATC110
    1985 Honda ATC250SX
    1984 Yamaha YTM225DX
    1983 Yamaha YTM200K - Parting out till gone!
    GONE BUT NOT FORGOTTEN:
    1985 Honda ATC250R
    1985 Yamaha Tri-Z250
    1986 Honda ATC200X
    1983 Honda ATC185S
    1982 Honda ATC110
    1978 Honda ATC90
