Firstly, get an online manual and get a friend to print it out on their computer. Secondly, you need to tune your trike. The manual will explain how to set the valves and set the static timing. Make sure you have a new plug and it's properly gapped. Make sure all your wires are connected, that all your electrical connections are good and that your ground is nice and clean. Make sure your chain is good and properly lubricated. Check your front and rear wheel bearings and that they are in proper order. Check your brakes for proper operation. No need to hurt yourself when you do get your trike running. Make sure you have your helmet for riding, no need to get hurt without wearing a helmet. Now, try starting your trike without the fuel cap on it. If the vent isn't working, the fuel cap will make it staved for fuel, if no change without the cap, then that's not your problem. You have to check your fuel tank for a clogged fuel line. Try running your gas line into a jar and check for flow. If the flow looks ok, the your carb may be gummed up. Just because you shot carb cleaner in there, doesn't mean you got all the little nooks and crannies cleaned out. You may have to take apart the carb, remove the jets and clean them out with small wires to make sure you have the small orifices free and clear. A shop manual will also tell you all your initial setting on the screws and such on the carb to try and help to get you started. Best of luck.
Nicholson 500x (Project)
Nicholson 185s
PK Racing Suspension 70
A+ Inc Suspension 70
AWS Aluminum 90 frame
