Results 1 to 15 of 23
Thread: Tecate with HID and LED's
    Crest California
    3,014
    Cool Tecate with HID and LED's
    Just thought I would share my Tecate with you guys, but this time it has a 55W HID and red LED's.
    So here it is with the sun turned on:
    And when the sun goes down:
    Needless to say, I won't have issues seeing at night. Thanks for lookin!
    LED obsessed
    2015 Yamaha FJ-09
    Oregon
    2,471
    Dam that's awesome, Let's see some details on harness & wires set up.
    If you have Bought a item from me, Please leave me feedback
    If your buying a item from me check my feedback
    Click on link ~ http://www.3wheelerworld.com/showthr...ceaserthethird
    OK
    5,450
    Kudos, you did a great job on that..
    Rides:
    1982 ATC70 (Lifan manual 125)
    1987 LT80 (piped, widened)
    My feedback thread
    RIP Trace.. Godspeed.
    I wouldn't have guessed a T3 would run an HID with the huge voltage jumps it makes. Any tricks involved?
    Crest California
    3,014
    Thanks guys. I'll try and get a diagram up of the harness if you guys want. It's not that difficult to make, just takes time and patience to figure things out.
    fabiodriven: No tricks, right now it's just a lot of guesswork based off of the math. My main concern is that the HID might suck too much current for the lighting coil to keep the battery charged. If that is the case, then I will have to drop to a 35 watt HID. Will post the results as soon as my battery comes in. Last nights blackout delayed my shipment until the middle of next week.
    I also want to try the system out with a 35w HID and the stock 55w lighting coil to see if it puts out enough to handle it, so upgrading to a Ricky Stator 65w coil won't be necessary.
    LED obsessed
    2015 Yamaha FJ-09
    May 2007
    Orange County, NY !
    1,673
    Don't forget to calculate the rear light and LED's. It adds up, depending how powerful your LED's are.
    Crest California
    3,014
    ^Actually, glad you mentioned the tail light.
    The way I have the bike wired up is with 11 lights. That's the headlight and 10 red LED's. There is 2 strings of LED's that are paralleled together. Each of the lights in each string is series'd together, so 5 LED's per string. 3 of the LED's on one string are inside of the tail light. It's actually a bit brighter than the stock 12V 5W light bulb, for just 3 LED's. I didn't make a fancy mount, I just soldered the LED prongs to the light bulb base, I'll have to pull it apart to get a pic. Not worried about the solder breaking off, and even if it does, I wired the wiring harness directly to the LED's so nothing goes through the original bulb base. Another thing, it's just a 200X light/bracket zip tied to the frame
    It will work for now. The math says I will be around 4.3 amps with all of the lights working at 13.6 volts, and the coil at 13.6 volts should be capable of putting out up to 4.7 amps. It's all going to be really close, so I'm hoping the math is close enough to the real world current draws.
    LED obsessed
    2015 Yamaha FJ-09
    Crest California
    3,014
    I thought I would put up a list of parts that I used for anyone who is curious as to what I have used sofar:
    -1x DDM tuning 55 watt Motorcycle HID Kit
    -10x 5mm Red 120* Beam Pattern LED's
    1x TrailTech Universal Voltage Regulator Rectifier
    1x Ricky Stator 65 watt Tecate lighting coil
    1x 12V 5AH Sealed battery
    LED obsessed
    2015 Yamaha FJ-09
    blackstone/ma
    1,491
    I've been interested in doing this for a while and will be veryu interested to see if the battery will stay charged
    May 2007
    Orange County, NY !
    1,673
    Crest California
    3,014
    I'm sure with the right setup that the battery will stay charged- I'm using a pretty power hungry headlight.
    My friend suggested that I try vision X Solstice LED's, so sometime in the future I might get some of them to try. I could run 2 spot and 2 flood lights and still be less than the 55w HID.
    riverrat: Not sure, I think they're 80 milli-watts, so 0.08 watts a piece.
    LED obsessed
    2015 Yamaha FJ-09
    May 2007
    Orange County, NY !
    1,673
    Ok that's really low. I have quite a bit of knowledge on LED's as I use them on my night flying planes. They have some really brite ones out there that can draw 3watts or more, and that would add up quick.
    Jan 2011
    mifflinburg
    525
    Yea i wanted to put some LED's on mine, Idk Now seeing that HID Headlight. I want that instead.. Nice thanks!
    Crest California
    3,014
    Quote Originally Posted by riverrat View Post
    Neat. I am using DW Foamies' Flite Lights on my airplanes. Total power consumption is 0.5 amps, and they're powered off of my flight packs.
    http://www.youtube.com/watch?v=6Dfrp...eature=related
    I've got a buttload of LED's on the way to try on something bigger.
    LED obsessed
    2015 Yamaha FJ-09
    May 2007
    Orange County, NY !
    1,673
    Is that you flying? If so you are pretty good, actually very good. My3-D stuff is rusty as I haven't flown much the last 3 years. Going to the NEAT fair next weekend where we have the night time balloon popping contest. That is what my Pheonix 100 with Demension engineering lights is for. I don't remember all the specifics because I set it up a few years back, but I think I draw close to 1amp. I use a separate BEC to drive the lights, off my flight pack. I purpose built that plane to compete in the contest. There can be as many as 30 planes trying to pop one balloon at times, and my plane can take the beating. Last year I had like 5 mid-airs, and a few encounters with the balloon string, and she kept right on flying.
    There are some pretty intense LED's you can get off ebay for cheap. I was thinking of tricking out my trike with LED's for headlights, and under the plastic. was going to hide the LED's in the number plate.
